mf135 main hydraulic
/ mf135 main hydraulic #1
Kzoo
Michigan
MF 135
After removing the cover and collapsing the pto my manual said it will lift out after removing the pins along the side. but it only rocks side to side. any ideas?
Do I need to break the tractor in half? There's not enough play in the pto to pull the pump. I hope my service manual didn't forget that little bit of info.
/ mf135 main hydraulic #3
Kzoo, repost this in Massey vintage forum so the experts will see it.
/ mf135 main hydraulic #4
Does the tractor have multi-power. If it does my manual states the tractor need to be split. There should be another pump fastened to the main pump if it does.
Not multi-power, but did get it out. Three bolts hold a retainer at the rear of tractor, undoing those allows you to pull the pto out to extract the pump.
/ mf135 main hydraulic #6
That's good news. I won't be so lucky if I have to do mine. I have multi-power. That makes it a bigger job.
Bobcat MT100 (A64126)
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
3269 (A63117)
3269 (A63117)
CLAYTON WARTHOG PNEUMATIC VACUUM (A64281)
CLAYTON WARTHOG...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
