mf135 main hydraulic
/ mf135 main hydraulic #1
Kzoo
Michigan
MF 135
After removing the cover and collapsing the pto my manual said it will lift out after removing the pins along the side. but it only rocks side to side. any ideas?
Do I need to break the tractor in half? There's not enough play in the pto to pull the pump. I hope my service manual didn't forget that little bit of info.
/ mf135 main hydraulic #3
Kzoo, repost this in Massey vintage forum so the experts will see it.
/ mf135 main hydraulic #4
Does the tractor have multi-power. If it does my manual states the tractor need to be split. There should be another pump fastened to the main pump if it does.
Not multi-power, but did get it out. Three bolts hold a retainer at the rear of tractor, undoing those allows you to pull the pto out to extract the pump.
/ mf135 main hydraulic #6
That's good news. I won't be so lucky if I have to do mine. I have multi-power. That makes it a bigger job.
2017 Kia Cadenza Sedan (A61574)
2017 Kia Cadenza...
2006 GMC W4500 10ft Box Truck (A61573)
2006 GMC W4500...
New Landhonor 72" Rock Bucket (A62679)
New Landhonor 72"...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
