MF135 Leaking Power steering fluid from steering column
/ MF135 Leaking Power steering fluid from steering column #1
chip01
Bartlett ,Texas
1970 MF-135
I have a 1970 MF135 that seems to be leaking power steering fluid out of the steering shaft housing, first I noticed it around the bottom of the shaft but now it is coming up to the top of the shaft as well. Any ideas on how to fix?
/ MF135 Leaking Power steering fluid from steering column #2
Do you own a shop manual? Replacing seals isn't usually rocket science. To get them out is usually the hardest part.Is your power steering working fine otherwise?No filter in the line that could be causing back-pressure,I guess? Get a shop manual or maybe somebody with a similar steering box will get on here and help you. don-ohio
/ MF135 Leaking Power steering fluid from steering column #3
if it's like a ford steering box, there will be a couple seals that need replacing.
/ MF135 Leaking Power steering fluid from steering column #4
:welcome:
/ MF135 Leaking Power steering fluid from steering column #5
i have 1971 MF backhoe with steering problems also i got a manual and neighbor with a 70s MF 175 i just joined today and away from home ill try to get you info asap
Thanks, I appreciate it.
213101 (A64276)
213101 (A64276)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
1992 International 8200 Spreader Truck, VIN # 1HSHEDPN2NH418329 (A65563)
1992 International...
2022 EZ-GO ELITE...
