Mf135 draft control lever stuck
   / Mf135 draft control lever stuck #1
Kiwitractor
Mf135 MF 165
MF135 draft control lever stuck,although I can move it just a touch.Hoping it may be in the control shaft externally,or do I need to look at internals?Lift controls work fine.
Any suggestions appreciated
   / Mf135 draft control lever stuck #2
Hi,
I've lifted the top cover off the hydraulics of a a similar tractor. From that experience I would say that this issue could be either the shaft that the lever rotates or the internal linkages attached. The internal linkages are a complex set up that control the hydraulic fluid flow to perform the position and draft control actions. They can break or wear and interfere with each other, causing a jam. I suspect that the hydraulic top cover will need lifting to inspect.
Get your hands on a MF135 manual, and beware, if I recall correctly, MF35's have a different utilisation of similar hydraulic control levers, suggesting that the internal linkages will be different, so don't use a 35 manual.
Thanks ,have freed it up with WD40 and problem was in the control shaft.
   / Mf135 draft control lever stuck #4
Phew, an easy fix.
Enjoy
1977 Cat 910 Wheel Loader (RUNS) (A50774)
1977 Cat 910 Wheel...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
Land Honor 84" 3 pt Disk (A50514)
Land Honor 84" 3...
