Backhoe MF GC2310
/ MF GC2310 #2
Did you bump one of the hydrostatic levers? I seem to remember that happening to my dad's GC2300 when one of the levers was partially bumped. Can't remember which one...
/ MF GC2310 #4
I find that if I leave the three point lift arms in full droop mode (lowered all the way) but something prevents them from achieving full drop, none of the other hydraulics work. Most commonly for me, the arms get caught on some portion of the backhoe.
Option 2 is that the hydraulic pump sheared its teeth.
Option 3 is a loss of hydraulic fluid from a leak. If you don't have a hydro filter guard, that's the first place I'd look. A chafed hydraulic hose is another possibility.
/ MF GC2310 #5
if you bump your deck lift lever from its neutral position , it will stall out your backhole.'
my lever sticks and doesn,t return to neutral ,
by itself.
took me 2 hrs to figure that out.
just make sure its in the neutral position .
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
2018 HINO SA (A58214)
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
Kubota L4701 (A53317)
206320 (A57192)
206320 (A57192)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
