3-Point Hitch MF 65 hydraulics
   / MF 65 hydraulics #1
muck0228
houston, tx
MF 65
I have a 1961 MF 65 gas. I want to get a turbo saw to cut ashe juniper. The model I want has a grapple operated by a single cylinder. Is there a way to set up my tractor so the 3-point hitch and a single cylinder will work at the same time?
   / MF 65 hydraulics #2
Late 100 series MF tractors that have built in auxilary hydraulic pump is what you need to work correctly, as these tractors have seperate three point and aux hydraulics pumps. Older models like yours have a single pump for three point only, can add a valve for cylinder control but three point is locked out for cyl control to work. Would be a pain to try to use with switching back and forth, also three point piston ring gaps will allow it to slowly lower while using cyl valve.
   / MF 65 hydraulics #4
Hi
If your tractor has only the main hydraulic pump Buy a selector valve this valve fits under the seat ,right hand side there is a transfer cap held on by two bolts ,remove the cap and there is the hydraulic stack pipe attached if it comes out with the cap remove it and fit new "o" rings refit the pipe making sure it is in the correct spot to check put the position control lever in transport and crank the engine just a little bit, if correct oil will come out .
Fit the selector valve and take the hydraulic supply from the selector valve to a dual /two spool control valve you should be able to buy from the same place ,if you want to be able to have a constant flow of oil to the cutter buy a spool with a detent hold spool this will allow you to select supply to the cutter without having to hold the lever.
next take a hose from the supply on the other spool and connect it to the front left hand port on the hydraulic lift cover that is the one the seat bolts onto,front left hand corner there is an inhex plug remove it and fit the hose 3/8 npt .
next take the return line from the spool valve and connect to either the transmission oil filler plug ,drill and tap the filler plug 3/8/npt and screw the return hose to this.
There are return ports under the seat on the left hand side but if you connect the return to this there is a chance that the oil will be aerated and the pump will suck in the aerated oil which is not good for anything,best to go to the filler plug.
To operate select remote on the selector valve and move the position lever fully up and the draft lever to up and leave them there operate the cutter with one control lever and the three point linkage with the other,to return hydraulics to normal move the selector valve to tpl ,Easy.
Hope this helps .
Regards Hutch
   / MF 65 hydraulics #5
P.S. If the hydraulics drop remove the lift cover and take the lift piston out and have the piston ring grove furthest from the oil pressure machined to take a three sixteen diameter "O" ring the grove dimensions are .1875 Inches deep and .288 inches wide this is to allow the "O" ring to ROLL in the grove, this will stop the lift arms dropping.
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2013 Nissan Rogue S SUV (A50324)
2013 Nissan Rogue...
Case IH 2608 8 Row Corn Head (A52349)
Case IH 2608 8 Row...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2005 KUBOTA L39 BACKHOE (A51242)
2005 KUBOTA L39...
KUBOTA KX033-4 EXCAVATOR (A51242)
KUBOTA KX033-4...
