MF 50D industrial
   / MF 50D industrial #1
pipreed
Vienne, France
Acme ALN 330WB
Hi, just started my industrial after a month or so, engine starts, increased the throttle / revs, everything OK, then after a few moments the revs decreases to nothing. I am thinking a fuel problem (lift pump / fuel filter / partial blockage, any ideas? thank you
   / MF 50D industrial #2
Change the f filter and get back to us..
There is a bleeder screw on the injection pump, by the name plate.. it’s a double screw with a 5/16 head.. loosen the 5/16 and crank the engine and look for air bubbles.. wait until u get solid fuel and tighten the screw..
   / MF 50D industrial
thank you, I'll give it a try
   / MF 50D industrial #4
If your machine has the filter that’s held together with the long bolt thru the center, the top oring goes UP IN THE GROOVE IN THE FILTER HEAD..
NOT ON the filter..
Seeing it petered out on its own, your gonna hafta bleed the injectors.. just loosen the line nut a couple of turns, and pull the throttle to wide open and crank the engine until fuel squirts out of the lines..
Make sure the shut off is pushed in and is in the RUN position..
Good luck
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
JOHN DEERE TS 4X2 GATOR (A51406)
JOHN DEERE TS 4X2...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
2010 LONE STAR TRAILER MFG. GOOSENECK TRAILER (A53843)
2010 LONE STAR...
2012 VOLVO BL70B BACKHOE LOADER (A51406)
2012 VOLVO BL70B...
