MF 50D industrial
   / MF 50D industrial #1
pipreed
Vienne, France
Acme ALN 330WB
Hi, just started my industrial after a month or so, engine starts, increased the throttle / revs, everything OK, then after a few moments the revs decreases to nothing. I am thinking a fuel problem (lift pump / fuel filter / partial blockage, any ideas? thank you
   / MF 50D industrial #2
Change the f filter and get back to us..
There is a bleeder screw on the injection pump, by the name plate.. it’s a double screw with a 5/16 head.. loosen the 5/16 and crank the engine and look for air bubbles.. wait until u get solid fuel and tighten the screw..
   / MF 50D industrial
thank you, I'll give it a try
   / MF 50D industrial #4
If your machine has the filter that’s held together with the long bolt thru the center, the top oring goes UP IN THE GROOVE IN THE FILTER HEAD..
NOT ON the filter..
Seeing it petered out on its own, your gonna hafta bleed the injectors.. just loosen the line nut a couple of turns, and pull the throttle to wide open and crank the engine until fuel squirts out of the lines..
Make sure the shut off is pushed in and is in the RUN position..
Good luck
Freightliner Truck (A42203)
Freightliner Truck...
2023 Bobcat E32i Mini Excavator (A44391)
2023 Bobcat E32i...
PT 1000 Gal Supply Tank (A44501)
PT 1000 Gal Supply...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A44391)
2005 Ford F-350...
YANMAR VIO17 MINI EXCAVATOR (A45333)
YANMAR VIO17 MINI...
2012 Ford Fusion SE Sedan (A44572)
2012 Ford Fusion...
