MF-32 Loader W/front pump
/ MF-32 Loader W/front pump #1
boatmoter
plant city florida
john deere 212// john deere 320 // ford 2120 loader
Hi everyone. I want to service my MF-32 Loader, it is a MF-20 industrial. it does not operate from the tractor internal hydraulics, has the front pump on it. all my manuals do not show the fluid capacity W/filter change on the loader. anyone know?
/ MF-32 Loader W/front pump #2
You probably figured this one out already, but I just did one recently and had the same question. The book says 8 gallons. I believe that is pretty close to what I had to use. The cylinders of course will contain about 1.5 to 2 gallons that is in that total number.
Thanks.. Im glad I bought 10 gallons. Im going to get around to it in about 1 month. still have to rewire the tractor and put the rebuilt carb on
I pulled the pump and the pump shaft is keyed, not splined. anyone know where I can buy or borrow a keyed shaft that has been modified to unscrew the threaded shaft from the collar that attaches to the crank pulley?
/ MF-32 Loader W/front pump #5
I have always used a pipe wrench to spin the shaft out. The threads are reversed (left hand) if memory serves me correctly. I think the shaft part number is 704997M92 (keyed female shaft), 708833M1 (male keyed shaft 12.6"), 1085975M1 (male keyed shaft 11-5/16")
cannot get to this one. the pump's shaft sticks into the center of the axle about 2". there's no pulley shaft sticking out to get hold of. Thanks for the shaft info, Im going to research that. if I cannot get a shaft reasonable, Im going to start loosening the front axle to get it about 1'2 away to get the belt past. unless another idea comes. would like to get a shaft and turn it into a wrench though.
/ MF-32 Loader W/front pump #7
I had a MF203 L/B. If I remember correctly, I used a proper size piece of threaded rod and ground a slot length wise in one end and welded a piece of key stock to the slot and inserted that end into the pump shaft and unscrewed the pump shaft. I might still have that tool and will post a picture of it.
/ MF-32 Loader W/front pump #8
You can buy shafting of the hole diameter already keyed from McMaster Carr or Grainger
Thanks. that sounds like a great idea.. Im going to try that. I have some round stock here,I may try welding a key way in that first
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
1996 Ford F-350 Pickup Truck (A64194)
1996 Ford F-350...
John Deere 24in Backhoe Bucket (A65640)
John Deere 24in...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
2022 EZ-GO ELITE...
