Oil & Fuel MF 245 fueling problem, injector pump??
/ MF 245 fueling problem, injector pump?? #1
dodgekyle87
Mf245 Massey furguson
I bought this Massey 245 with the ad3.152 Perkins diesel in it. Not running
Injector pump was not delivering fuel to injectors, plenty of diesel was comming out of supply line to injector pump.
I disassembled pump and found that the stop bar inside the top cover was frozen in the off position. I disassembled further and found the injector pump plungers frozen.
I cleaned and unstuck these and resealed with a kit along with new vanes, new vane pump bore and new vane pump end cap.
Tractor now starts but won’t idle and revs slowly.
I removed the return line at the injector pump and found pressurized fuel comming from filter housing which doesn’t seem right.. however with this line loose and the return for injector pump spilling on ground the tractor still won’t rev quickly and won’t idle
If anyone has a manual or advice I’d sure appreciate it
/ MF 245 fueling problem, injector pump?? #2
how did u get to the plungers.??
The most common mistake is, people don’t know that there’s a piston in the sleeve in the end plate..because it’s frozen in the sleeve..
Another common mistake is they put the pressure adjuster in up side down..
Good luck
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61165)
IMPORTANT PLEASE...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
1999 8ft. Tampa Trailers S/A Utility Trailer (A59231)
1999 8ft. Tampa...
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
2019 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2019 Ram 2500 4x4...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
