MF 165 identifaction
   / MF 165 identifaction #1
Sean165
Greer, sc
MF 165
The serial number on my Perkins engine is 29D6387 -does this mean it was produced prior to May 31, 1966? Can any further identification as to the year be determined? Thanks
   / MF 165 identifaction #2
Should be a tractor SN tag on lower dash panel below battery cover, that is # needed to find build year.
Thanks - I will check. Also, I did talk to you last week concerning the injector pump. I am in the process of taking it off to send you - I will call to confirm the address,etc. in regards to taking it off - can I just remove the crankcase fill port small plate, than remove the 3 bolts from the gear - leaving the dowel pin and gear in place?
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2013 CATERPILLAR 320EL EXCAVATOR (A51242)
2013 CATERPILLAR...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
Crate of New Hydraulic Hoses (A47384)
Crate of New...
CAT 973 (A47384)
CAT 973 (A47384)
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
