MF 1643 Thinking of Trading for a MF1749 or MF 1754
   / MF 1643 Thinking of Trading for a MF1749 or MF 1754 #21
More weight will help you, not hurt... You'll have plenty of HP to handle the weight with either the 49 or 54
   / MF 1643 Thinking of Trading for a MF1749 or MF 1754 #22
I love my 1742, if it's an upgrade you really want to do then it's worth it
   / MF 1643 Thinking of Trading for a MF1749 or MF 1754 #23
My 1758 nicest tractor I have owned. Soot regen cycle not an issue for me, particulate filter and emissions stuff was a worry but I am past that and don't notice it sometimes when it does cycle. I like my cab on the 1700 series has been a summer from **** with humidity and bugs and storms here in MN. The A/C is a must and I am not sure how I have done without in past. top speed over 20 mph with the HST. Skid steer style loader and front mount hyd. also the only way to move snow. I can haul *** with a 96" Bobcat snowblade. Ag tires loaded and I have traction up the Kazoo but they are tough on grass. Loader and Hyd. system is strong and I really feel these are the best tractor out there in and even above their $ range. I get more done with this Massey than I did with several other tractors. Part of it is having a cab and working in weather you wouldn't be out in with a open station
View attachment 478047View attachment 478048View attachment 478049View attachment 478050View attachment 478051
What kind of deal did bobcat give you on this? I am looking to trade my 2615 for something similiar but can't quite justify the deal they are throwing my way.
   / MF 1643 Thinking of Trading for a MF1749 or MF 1754 #24
jibe717,
PM sent
Ended up buying a MF 1754 HST cab in late September. I've put around 55 hours on it so far. Great tractor! For the size, weight and HP this thing is a beast!!! Every time I run it, I'm amazed at what it is capable of doing. Between the HST and the power of this tractor, I've cut the time required for a normal daily snowplowing effort in almost half. I've had some issues with the HST (tractor wouldn't move in reverse), bad switch on the HST pedals, 3 point lift handle misaligned and jerky 3 point lift. I have some posts describing the issues. I fixed most of the issues myself with parts, filters and hydraulic oil assistance from my selling dealer. Main HST issue seems to have come from overfilled and contaminated hydraulic oil and then plugged filters. Tractor is probably running at 95%. Still having an intermittent problem with HST going into forward or reverse. Press on the forward and reverse pedals, engine revs, tractor doesn't move. Overall, even with the issues, this is a great tractor! However, if in a couple of months, I don't have these issues sorted out, it won't be as great!
   / MF 1643 Thinking of Trading for a MF1749 or MF 1754 #27
Wow, sorry to read about those problems. I have the exact same model and it just goes. Hope you get them sorted out soon. I love my reliable machine.
461058d1458102913-1758-review-mapletbn-jpg
461057d1458101554-piranha-tooth-bar-gc1720-dl95-blackberries-jpg
Biodegraded- appreciate your reply. It seems to be a great tractor if I can get the bugs worked out! Since we have the same model tractor. Do you ever run into a situation where you step on the forward and/or reverse pedals, say throttle is set at 2000 rpms, and your tractor engine revs to 2600 rpms for a couple of seconds and then waits for a couple of seconds to move? Almost, like you are on ice but the wheels don't spin. Also, have you ever noticed any jumpyness in the 3PNTLIFT when picking up a heavy implement no matter how the flow rate dial is set? Thanks - Ted
   / MF 1643 Thinking of Trading for a MF1749 or MF 1754 #29
I have experience none of those things. Good luck with your rig.
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
2012 Ford F-250 Crew Cab Pickup Truck (A50323)
2012 Ford F-250...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2019 Bobcat E45 Mini Excavator (RIDE AND DRIVE) (A50774)
2019 Bobcat E45...
Appalachain 2 Axle Fender Trailer (A50774)
Appalachain 2 Axle...
