MF 1533 power beyond vs remote valve kit ???
   / MF 1533 power beyond vs remote valve kit ??? #1
saiga
meridian, idaho
2005 MF 1533
hi all, so my questions are these: is a PB and remote valve kit the same thing, dealer wants 1000.00 for a kit, im wondering if i can come off my existing joystick for loader... or maybe just go with A pto pump.. all of this is so i can run a Bradco 9md2 backhoe attachment. any and all thoughts would be appreciated. it just seams like there has got to be a cheaper way to get two rear remotes.
kelly
   / MF 1533 power beyond vs remote valve kit ??? #2
Is the backhoe used? You should be able to plumb into the tractor hydraulics with a kit from AGCO or Bradco. You should be able to do this for a couple hundred bucks. That way you can have live hydraulics to feed the backhoe. Remotes are not the way to power a backhoe. A PTO pump would also work, you would need a tank to have oil though.
hi, yes the backhoe is used. the unit curently has two lines running from it with male and female couplers. i havent tried bradco yet. the kit that my MF dealer wants to sell would give me the two couplers at the rear of the tractor, but at quite the cost.
   / MF 1533 power beyond vs remote valve kit ??? #4
Welcome to TBN:D
No, they are not the same. The PB has flow continuously. There is NO valve to control a PB circuit.
The remote has a valve to control flow to one or more circuits, usually with DA (double acting) cylinders attached to them.
If your FEL valve has 7 hoses connected to it, the you can plumb the power beyond loop yourself for the price of 2 hoses, some QD's and some fittings-probably under $200 total cost.
   / MF 1533 power beyond vs remote valve kit ??? #5
Maybe the dealer is confused on what you need. Is your loader valve the factory tractor mounted one? If so the 2 hoses, couplers, 90 degree adapters and diverter plug should really only cost about $100. Also, does your backhoe have a subframe mount for your tractor?
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2009 Ford F-150 Pickup Truck (A59230)
2009 Ford F-150...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2008 JCB 190 ROBOT SKID STEER (A60429)
2008 JCB 190 ROBOT...
