MF 1529 wont keep running
   / MF 1529 wont keep running #1
JJorT
Massey Ferguson 1529
I have been trying to track down the following problem for about 2 years now... My tractor will start and run but after a few mins or half an hour it will stop... it might start right up or it might take a few times to catch... when I turn the key it will run and when I let go it will stop.... it sounded like I had a problem with the fuel solenoid so I removed it and the tractor ran fine... I replaced the fuel solenoid and the problem persisted.... it seems like the pull circuit is working properly but the hold circuit is either shorting out or has a broken wire.... I ran a wire direct from the battery to the hold circuit and the tractor works fine...I just have to disconnect it to turn it off... PITA. So I figured I would have a go at tracing the wire.. I removed the plastic dash and was undoing all the connectors and spraying with contact cleaner... (it was filthy under there)... I left the tractor running and was wiggling connectors when it suddenly died.... looks like it might have a bad engine stop relay.... anybody have any idea what the part number is for this?.... I would like to replace it but I cant find any info on it
   / MF 1529 wont keep running #3
G'day Mate and welcome to TBN from Downunder.
You didn't mention it in your post but have you put an inspection camera down into the fuel tank? You could have a biological growth or an obstruction happening. A blocked air-vent on the fuel cap could also be a contributing factor.
Enjoy the site... from wherever in the world you're from.
I will post some pictures once my post count reaches 3
Hello
I havent put a camera in the fuel tank, I am pretty sure that my problem is electrical as it will run fine with the fuel solenoid removed.
Thank you for the suggestion
Btw, I am located just outside of Kingston, Ontario, Canada
cheers
JJ
   / MF 1529 wont keep running #6
Ok did you find the fuel relay online and does it look the same
I will now try to post some pics of the suspect relay
It is located on the right side just under the dash cowling
Here is a picture of it removed
I jumped the power lead from the ignition to the wire going to the hold circuit in the fuel solenoid and now it will run fine and turn off with the key....not sure what the purpose of this relay is
   / MF 1529 wont keep running #8
Please add you general location to your profile.
Periodically, it may help others to help you.
   / MF 1529 wont keep running #9
I don't think that's a relay The one to the right of the red arrow is a relay .
   / MF 1529 wont keep running #10
I believe it pulls the fuel stop in on 12 volts then holds it in on a lower voltage ... jd has something like that I had trouble with...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A55745)
2018 KENWORTH T800...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2019 KUBOTA SVL75-2 SKID STEER (A52706)
2019 KUBOTA...
CATERPILLAR 126" PIN ON BUCKET (A52707)
CATERPILLAR 126"...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
