MF 1433 Parts
   / MF 1433 Parts #1
wayne48
Vermont
MF 1433v
Parking brake on my Massey stopped engaging today. Investigation revealed that the teeth on the brake pedal that the parking brake lever engages had worn down from use.
Temporary fix was to adjust more play in the brakes so that the pb lever could engage good teeth higher up on the brake pedal.
This works but I'm not comfortable with this as a permanent fix.
Permanent fix would be to replace the main brake pedal that has these teeth (left side).
SO all that being said, starting searching on line for the part. After an hour, no joy!
Who has had success at finding parts on line for an MF 1433 and where did you find them?
OR do I just need to bite the bullet and go to my MF dealer for the part?
Thanks for any advice.
   / MF 1433 Parts #2
How about improvising, overcoming and adapting? Remove the pedal and have a welder or fab shop make a more permanent repair? Surely a beefed up pedal would be better than a replacement that is just going to wear out like the original pedal.
   / MF 1433 Parts
Point well made teampryor. Talking to a welder now.
Also much thanks for the link to Agco Parts.
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2008 CATERPILLAR 325DL Long Reach (A52384)
2008 CATERPILLAR...
