MF 1433 Parts
   / MF 1433 Parts #1
wayne48
Vermont
MF 1433v
Parking brake on my Massey stopped engaging today. Investigation revealed that the teeth on the brake pedal that the parking brake lever engages had worn down from use.
Temporary fix was to adjust more play in the brakes so that the pb lever could engage good teeth higher up on the brake pedal.
This works but I'm not comfortable with this as a permanent fix.
Permanent fix would be to replace the main brake pedal that has these teeth (left side).
SO all that being said, starting searching on line for the part. After an hour, no joy!
Who has had success at finding parts on line for an MF 1433 and where did you find them?
OR do I just need to bite the bullet and go to my MF dealer for the part?
Thanks for any advice.
   / MF 1433 Parts #2
How about improvising, overcoming and adapting? Remove the pedal and have a welder or fab shop make a more permanent repair? Surely a beefed up pedal would be better than a replacement that is just going to wear out like the original pedal.
   / MF 1433 Parts
Point well made teampryor. Talking to a welder now.
Also much thanks for the link to Agco Parts.
2019 RBR Venturi 380 (A53473)
2019 RBR Venturi...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2012 Ford F-350 Reading Service Truck (A51692)
2012 Ford F-350...
1997 MONON 102" X 53' T/A VAN TRAILER (A51247)
1997 MONON 102" X...
