MF 1433 Parts
   / MF 1433 Parts #1
wayne48
Bronze Member
Vermont
MF 1433v
Parking brake on my Massey stopped engaging today. Investigation revealed that the teeth on the brake pedal that the parking brake lever engages had worn down from use.
Temporary fix was to adjust more play in the brakes so that the pb lever could engage good teeth higher up on the brake pedal.
This works but I'm not comfortable with this as a permanent fix.
Permanent fix would be to replace the main brake pedal that has these teeth (left side).
SO all that being said, starting searching on line for the part. After an hour, no joy!
Who has had success at finding parts on line for an MF 1433 and where did you find them?
OR do I just need to bite the bullet and go to my MF dealer for the part?
Thanks for any advice.
   / MF 1433 Parts #2
How about improvising, overcoming and adapting? Remove the pedal and have a welder or fab shop make a more permanent repair? Surely a beefed up pedal would be better than a replacement that is just going to wear out like the original pedal.
   / MF 1433 Parts
Point well made teampryor. Talking to a welder now.
Also much thanks for the link to Agco Parts.
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
2014 Ford F-550 Altec Bucket Truck (A51692)
2014 Ford F-550...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
RYOBI 18V ELECTRIC 16" PUSH LAWN MOWER (A51248)
RYOBI 18V ELECTRIC...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
