MF 135 Starter / Solenoid replacement
/ MF 135 Starter / Solenoid replacement #1
jmwall67
Apex, NC
MF 135
Hi All,
My MF 153 diesel looks like it needs a new solenoid on the starter. When I turn the key, there is no voltage on the connection from solenoid to the starter. It looks like it will be easier to just replace the solenoid than replace the entire starter/solenoid combo. To replace the whole starter I'm going to have to remove the power steeping hoses (they run from the pump over the starter to the steering wheel) and to remove the power steering hoses I'm going to have to remove the alternator.
So my question is: are there any tricks or issues with removing just the solenoid? Looks like 2 small bolts and electrical wires and it comes right off. But since I've never done this I'm not sure if there is anything inside the starter housing that I need to know about before pull it off??
Thanks,
Jeff
/ MF 135 Starter / Solenoid replacement #2
I think it is pretty straight forward with no "tricks" or special considerations. Be sure to remove the ground wire from the battery as step #1
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2016 KUBOTA SVL75-2 SKID STEER (A65056)
2016 KUBOTA...
2013 Ford F-150 Crew Cab Pickup Truck (A66736)
2013 Ford F-150...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
2000 Hino (A64194)
2000 Hino (A64194)
