MF 135 hydraulic problems
/ MF 135 hydraulic problems #11
see any spring clips in the sump housing?
I'm familiar wioth the older fergy system.. but not the 35/135...
soundguy
Thanks but seem to have found the answer after phoning local MF dealer chandlers in stamford, UK
It is apparantly a grub screw that scews into the link arm cross shaft and locates in the "dogbone" groove that holds it in place
So this has broken off i guess as i didnt notice a hole
Anyway new one ordered along with seals and other bits we need so thanks
progress though means no top cover gasket, just tube of instant seal!!
still looking for a decent set of drawings althogh the ones on here are start
Nige
/ MF 135 hydraulic problems #13
yech.. I hate gasket in a can... any orings around the high pressure line in the top cover?
soundguy
soundguy
yep ordered seals as well thanks
hoping relief is ok as its 44 quid from MF dealer although others do them for a tenner
/ MF 135 hydraulic problems #15
if there are orings around the high pressure line, then they will do te job of sealing the pressure.. and the gasket in a can can just keep the dirt out of the sump, and make the lift cover glued down and nigh impossible for the next poor sole to remove :)
( but should work ok! )
soundguy
/ MF 135 hydraulic problems #16
In my opinion you would be better off getting a roll of gasket material an cut your own. Collapsable anttena material and pieces of thin wall tubing work really good for cuting the bolt holes and you can use these right in the holes for the piece your making.
/ MF 135 hydraulic problems #17
that and a ball peen is an easy way to make a gasket when you have the sump open to work with.
soundguy
KJ K3325 33'x25' Barn Shed (A60463)
KJ K3325 33'x25'...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
2002 POLAR TANK (A60736)
2002 POLAR TANK...
John Deere 344L Loader (A60352)
John Deere 344L...
