MF 1250 4WD
/ MF 1250 4WD #1
toa5150medic
Blythe, CA
1995 Massey Ferguson 1250
I noticed the 4WD was not working on my 1995 MF1250. Upon inspecting underneath, I noticed the drive shaft from the transmission had come disconnected from the shaft going into the front differential. There appears to be a connector that slides forward and holds the two shafts together. I cannont get that piece to slide forward. And if it does what keeps it from slipping off again? Sorry about my lack of proper terminology, but I am new to the world of tractors. Thanks for any help.
/ MF 1250 4WD #2
I've seen this before, their is usually a split ring, and a collar that retains this item in position, by the looks of what your describing, you sheared a pin, need a picture to make sure and also make sure you have all the part numbers in this area, these parts are not expensive, however, you do have to be exact.
Kenneth J Kinney
2140 (A65055)
2140 (A65055)
36" X 10' ADS DRAINAGE PIPE (A65055)
36" X 10' ADS...
UNUSED RAYTREEE RMH680 HYD HAMMER (A65055)
UNUSED RAYTREEE...
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A64557)
2017 Forest River...
2010 GMC W5500 HD 16ft. Box Truck (A64556)
2010 GMC W5500 HD...
UNUSED JCT 60" CLASS8-8000 LB CAP PALLET FORKS (A65055)
UNUSED JCT 60"...
