MF 1250 4WD
/ MF 1250 4WD #1
toa5150medic
Blythe, CA
1995 Massey Ferguson 1250
I noticed the 4WD was not working on my 1995 MF1250. Upon inspecting underneath, I noticed the drive shaft from the transmission had come disconnected from the shaft going into the front differential. There appears to be a connector that slides forward and holds the two shafts together. I cannont get that piece to slide forward. And if it does what keeps it from slipping off again? Sorry about my lack of proper terminology, but I am new to the world of tractors. Thanks for any help.
/ MF 1250 4WD #2
I've seen this before, their is usually a split ring, and a collar that retains this item in position, by the looks of what your describing, you sheared a pin, need a picture to make sure and also make sure you have all the part numbers in this area, these parts are not expensive, however, you do have to be exact.
Kenneth J Kinney
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A67148)
2021 UTILITY VS2DX...
2013 International DuraStar 4300 General Cable T40-C 35ft. Bucket Truck (A64194)
2013 International...
2016 Ford Expedition SUV (A64557)
2016 Ford...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
