MF 1040 Hydraulics/Loader Issue
/ MF 1040 Hydraulics/Loader Issue #1
davidshobson
Nashville, TN
Massey Ferguson 1040
I have a 1985 MF 1040 with loader. I replaced four lines on the loader after blowing one. I also replaced the hydraulic filter. Now the loader will only go up and the curl action wont work at all. I cracked several joints in the system looking for air, but found only oil. I replaced the loader valve a year ago and had a similar issue, but it eventually worked out. I can't work this out, because I can't exercise the system as it only goes up.
Any ideas?
Thanks in advance
/ MF 1040 Hydraulics/Loader Issue #2
Did you replace all line at one or did you replace them one at a time?
I guess all at one and you crossed a line.
I would disconnect or crack each line and work your valve to check if the fluid flows or leaks where it should.
/ MF 1040 Hydraulics/Loader Issue #3
Using a loader valve with PB, you should have 7 hoses.
IN hose
OUT/TANK hose
PB OUT
4 cyl hoses
Pump flow goes to IN port.
PB hose goes downstream to the next valve.
Cyl hose conect to the appropriate port on the cyl.
OUT port goes to the OUT/RETURN line.
Caterpillar 350/350L Excavator Service and Parts Manuals (A63117)
Caterpillar...
2002 48ft. T/A Flatbed Trailer (A61573)
2002 48ft. T/A...
2026 Electric Tricycle (A64194)
2026 Electric...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2017 Jeep Renegade SUV (A61574)
2017 Jeep Renegade...
