MF 1010 4x4
/ MF 1010 4x4 #1
mac02554
nantucket ma
mf1010 & Kubota 5400
I have a MF 1010. Great little tractor. Recently I was out plowing slow and it kept going slower and slower. . Now I have lost all forward & reverse ability. The hydraulics still work fine for the 3 pt hitch & bucket in front. Any suggestion? I need to airreate a few lawns. & fertilize. Thx Mac
/ MF 1010 4x4 #2
I realize this is an old post , but wondering if someone had a solution
My 1010 recently stopped moving , and pto is not working
I suspect the clutch is worn out
Suggestions?
/ MF 1010 4x4 #3
Try it in a lower range. When a clutch slips you usually lose the higher gears first. Check your clutch adjustment. You should have about an inch of free play on the clutch pedal before it begins to disengage.
/ MF 1010 4x4 #4
Ya , I've checked clutch free play and have even tried it with linkage removed to give it maximum engagement but it's slipping badly and won't even turn the pto shaft let alone the hydrostatic transmission in low or high range
/ MF 1010 4x4 #5
Ya time to split and replace the clutch. Have fun. I quit buying tractors with dry clutches decades ago. Dry clutches are the weakest link in any transmission system and the hardest to replace as well.
PORTA POTTY (A67714)
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2005 Oskkosh MK48A1 8x8 Articulating Tactical Truck w/ MK14 20ft. Flatbed Container Hauling Trailer (A66736)
2005 Oskkosh...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A68183)
2008 Allmand...
1991 BRENNER TANK TRAILER (A67714)
1991 BRENNER TANK...
2018 Holbart 210 MVP Mig Welder (A68183)
2018 Holbart 210...
