Metric wonderment experience
/ Metric wonderment experience #1
Edstir
I've been repairing my 35TLB Backhoe and purchased a Tap and Die set that imcluded fine and coarse metric thread components. After I chased a few bolts and threaded metal parts I wondered if my T & D set was out of spec. When I went to purchase new bolts I found out there is also an EXTRA FINE category not included or mentioned in my metric set. At my age (64 today) it is hard to see the difference between fine and extra fine. I was not aware of the extra fine thread category and just wanted to alert all our members. If there are any other unusual metric quirks I may experience and you want to share the knowledge I would appreciate the education.
/ Metric wonderment experience #2
It's not only Metric that has more than two sizes. There are four in SAE. Coarse, Fine, Extra Fine and National Special. I also on rare occasions when working on industrial type manufacturing machinery (usually import equipment) run across a whole other type thread, British Whitworth and oh let's not forget Acme thread.
Here's a example of how screwed up the US thread system is. Let's use a 3/8 as the example of all the available thread pitch's.
3/8 - 16 Coarse
3/8 - 24 Fine
3/8 - 32 Extra Fine
3/8 - 18, 20, 27, 28, 40, 48 National Special
3/8 - 12 Acme
/ Metric wonderment experience #3
Edstir, I have both inch and metric threads between the accessories and tractor. I understand your frustration with matching thread pitch. What I do is lay the tap and bolt or stud next to each other. When you try to mesh the threads together any difference in pitch will stand out in a fairly short # of threads. If you have a mixture be real careful with diameter too - very close pitch crossovers occur between the 2 systems. Measure your bolt with a caliper. The tap will always be a little bigger than a bolt thread - about 1 or 2%.
larry
/ Metric wonderment experience #4
3/8 - 16 Coarse
3/8 - 24 Fine
3/8 - 32 Extra Fine
3/8 - 12 Acme
Wow, I never knew that. I deal with 1/4-20 and 1/4-28 and stuff like 10-32 but did not realize the others you mentioned existed. Thanks.
/ Metric wonderment experience #5
For example if you seen a gear or hub puller, that's Acme
/ Metric wonderment experience #6
<dang Tab key!>
But like you, I'm not sure what "National Special" is either?
/ Metric wonderment experience #7
3/8 - 16 Coarse
3/8 - 24 Fine
3/8 - 32 Extra Fine
3/8 - 12 Acme
Of course, let's not forget NPT (National Pipe Thread) that are the tapered pipe threads. According to my 21st edition of Machinery's Handbook, we have the following pipe threads:
NPT - American National Standard Taper Pipe Thread
NPTR - American National Standard Taper Pipe Thread for Railing Joints
NPSC - American National Standard Straight Pipe Thread for Couplings
NPSM - American National Standard Straight Pipe Thread for Free-fitting Mechanical Joints
NPSL - American National Standard Straight Pipe Thread for Loose-fitting Mechanical Joints with Lock-nuts
NPSH - American National Standard Straight Pipe Thread for Hose Couplings
Then there is:
NPTF - American National Standard Dryseal Taper Pipe Thread for Pressure-tight Joints
...and the variations of:
NPTF-SAE Short - Dryseal SAE Short Taper Pipe Thread
NPSF - Dryseal ANSI Standard Fuel Internal Straight Pipe Thread
NPSI - Dryseal ANSI Standard Intermediate Internal Straight Pipe Thread
Let's not forget square threads, which are similar to ACME; but aren't.
To paraphrase Mr. Spock from the episode "I Mudd", "There is a coarse thread, a fine thread, an extra fine thread, a taper thread, a dryseal thread, a whole plethora of threads; but only one ACME thread."
I wonder how many of these thread types are still in existence. Does anyone have the latest (27th I believe) edition of Machinery's Handbook to verify?
Thanks to all that responded. I have been enlightened. The local jobbers I been to for hardware are bewildered when it comes to metric. Menards has a new bolt display with coarse and fine but no extra fine that I could find. I think I will order bolts by their specific Kubota part number to make sure I have the right kind. Metric tools are easy to find but the hardware leaves a lot to be desired.
/ Metric wonderment experience #9
Extra fine is not very common.
Usually you only use metric coarse, I dont think I have ever used anything else.
/ Metric wonderment experience #10
Kubotas use fines.
larry
/ Metric wonderment experience #12
Then there is:
Don't forget the threaded bolts/screws on my kids wooden toys. They look to be ultra course thread turned on about a 1/2" maple dowel. :p
/ Metric wonderment experience #14
hazmat said:
For harder to find hardware
McMaster Carr
McMaster-Carr is my favorite place to get hardware followed by MSC Direct MSC Industrial Supply Co. Home Page, then MSC's sister company Enco Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies , and finally Fastenal Home | Fastenal
All of these places are pricey; but they have what you want, what you need, and stuff you never knew existed.
For what it's worth; I have a self imposed $50 minimum order, which doesn't take long to achieve. I do this because I have found these places to be such valuable resources for stuff, that I would hate to see them stop selling to lowly little homeowners like me and take the snotty Grainger attitude. Heck, Grainger is even snotty to its corporate clients.
Even though I place the order and know what's in the box; when the UPS driver leaves the order on my doorstep, it's like opening packages on Christmas day for me.
/ Metric wonderment experience #15
And to confuse things even further, an M5 and a 10-32 are so close that you can thread a nut from one system onto a bolt from the other!!!
/ Metric wonderment experience #16
Assuming we'd want to :)
