Snowblower Meteor Snowblower chains?
/ Meteor Snowblower chains? #1
dylan
ottawa, canada
Toolcat B series
I was looking at a meteor snowblower today and I was wondering if anyone knows what the chain does that is wrapped around the pto shaft where it meets the blower fan? Is is a shear bolt type attachment or does it join the pto shaft to the fan shaft?
Any input is welcome.
thanks dylan
/ Meteor Snowblower chains? #2
I would think it would be to support the shaft in the event a shear pin breaks and it slides of the fan shaft.
Ken
/ Meteor Snowblower chains? #3
Good evening Dylan,............ Are you refering to the chain that prevents the outer cover on the PTO shaft from turning ? That is the only chain that I can think of. Have a safe and Merry Christmas. Garry :D
/ Meteor Snowblower chains? #5
The driveshaft has a chain on each end. You clip one chain to the tractor and the other to something on the blower. It keeps the driveshaft cover from rotating. You have to make sure you grease the fittings on the cover. You will notice little plastic grease fittings, without grease the cover will not operate properly.
/ Meteor Snowblower chains? #6
thanks dylan
Hi Dylan - does it look something like this? This is a chain-type flexible coupling - a piece of two-row chain wrapped around face-to-face sprockets.
These are sometimes used in machinery to accomodate small misalignment between drive components. Flexible couplings allow shaft centerlines to be slightly off and still be coupled without shims and tedious assembly work. The sprockets are often keyed to the shafts and usually are not shear devices.
Ah yes, that's exactly what I was refering to. thanks for the explanation and the picture.
dylan
HUSKIE HYD HAMMER (A62131)
HUSKIE HYD HAMMER...
2022 Coyote Renegade Trailer (A63116)
2022 Coyote...
UNUSED WOLVERINE MPF-11-2500G MINI PALLET FORKS (A62131)
UNUSED WOLVERINE...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
Zero Turn Mower (A59231)
Zero Turn Mower...
