metallic coating on steel?
   / metallic coating on steel? #1
Rusty4242
Western Mass.
Kubota BX23
Got a peice of steel plate, 1/2 x 6 x 9, that I preped with my angle grinder prior to welding on this splitter I'm building. . Had sort of a reddish ( red lead?) hard coating over a metallic coating(plating) of a lighter color than the steel underneath . Ground it all off of areas to be welded, but was wondering what the metal over the steel could be. Didn't look like galvanizing. Wasn't cryataline looking. I hope it wasn't cadmium. I did wear a dust mask and used a fan for ventilation. The plate is stamped with 6P2 in 1/2 inch hight letters. What do you think?
   / metallic coating on steel? #2
Based on the intelligence of the last few of your posts, I can say with 100% certainty it was Lead paint. ;) (J/K)
No really, it probably was lead paint, especially if it was Red :eek: Good that your wearing a mask when you sand or grind.
Larry
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
Case 1020 25ft Draper Head (A56436)
Case 1020 25ft...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
