ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #1
Aging TOO Fast
Bronze Member
someplace lost
none
So Here is the CRAZY QUESTION of the DAY.........
Is there any way, to SAFELY remove, strip, or dissolve galvanized coating on
pipe so as to use it (the pipe) to safely weld on it, and get good non- contaminated
weld.
I know that galvanized coating is VERY VERY BAD to put heat to it and NOT to BREATH IT
( if one even tried to weld
on something that might have some galvanized coating remaining on it.)
If one uses a grinder to strip, there are the dust particles, and still have the coating inside the pipe.
Just wondering if there might be a safe way to reclaim steel that might be able to be
welded instead of just bolting it.
Just thought I would ask.
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #2
P100 respirator.
Grind galv off.
Weld as normal (while wearing respirator), but try to keep your face out of the smoke. A slight breeze from behind will help make sure that its not strong enough to blow away shielding.
thanks for the comments!
besides Todd727 's link
how to remove galvanized coating without grinding? - WeldingWeb™ - Welding forum for pros and enthusiasts
I found a couple others to share-
one I found elsewhere, and one was referenced in an older TBN post;
Weld Talk Message Board and Online Forum - Hobart Welders
older TBN thread-
Re: Weld black pipe or galvanized
HERE IS THE STORY LINKED in a post- I thought it was worth sharing
and having here without chasing a link........ (there are pictures in original
text that won't copy with text here. goto original article to see them)
A Case study
Death by Metal Fume Fever
Zinc Metal Fume Fever : A Case Study : Blacksmithing How-to on anvilfire iForge
SAFETY - III : A Case study
Posthumous Demonstration by Jim Paw-Paw Wilson
Paw Paw's Forge Home Page
May 13, 2005
This is the second safety demo by Jim "Paw-Paw" Wilson based on real life events. Sadly this will be his last. We are presenting it the way he would have wanted.
Paw-Paw 1940 - 2005 Well folks. This is a **** of a way to do a demo. I did something stupid that I knew better than to do, thinking I was tougher than a little smoke. Well, I miscalculated and now I am dead.
My friends will have to finish this for me. . .
Sheri, I love you. Please forgive me.
Figure 1 We will never know what Jim was thinking that day. He was probably just trying to get a job done the quickest easiest way he knew how.
The parts to the right were 2.5" galvanized pipe. They were to be welded up as part of a stock rack we think. To weld them they needed the galvanizing removed.
Jim burned off the zinc in his gas forge.
Figure 2 Burning zinc looks similar to burning magnesium. It flares off white zinc oxide smoke and leaves heavy soot like yellow and white oxide deposits where the smoke cools. In the metal working shop we are often exposed to small amounts of zinc smoke without ill effect. It is common in brazing, casting brass and ocassionally welding.
However this was not a small amount of zinc smoke. It was thick enough in his well ventilated shop that Jim wisely sent his helpers outside. Why he stayed we will never know.
Figure 3 There was so much zinc that it reacted with the refractory lining causing the ITC-100 coating to flake off. Around the door gasket area there were 1/16" thick deposits of zinc oxide. There is no question that Jim was exposed to significant amounts of zinc oxide smoke as he removed the flaming parts from the forge and quenched them.
Two weeks later when the forge was fired up it was still generating zinc smoke and fumes.
JOCK
D After this event Paw-Paw was very ill for a couple days. He thought he was over it and went on a road trip. A week after the exposure he came down with double pneumonia and had to be brought home. A week later he was dead.
Prior to this Paw-Paw had problems with emphysema and this is a factor in his case. However, metal fume fever can kill the young and healthy or leave lasting effects.
JASON
DUNCAN Today is Friday May 13, 2005. I am a blacksmith for a fabrication shop, and have many friends in the same profession. One of my friends is a man called PAW PAW. His real name is Jim Wilson, and he passed away today.
He no longer suffers from health problems. He no longer feels pain. He no longer feels anguish. He never seeked fame.
A crusty old blacksmith from Winston Salem N.C. Has gone to his reward. For he truly was the salt of the earth, the light that led the way for so many, A loving husband to his wife Sheri. A devoted father and foster father, and a faithful friend.
His passing has brought the smiths around the world together in mourning. From the first time newby, to the skilled master. The most active blacksmithing website anvilfire.com has had numerous posts concerning the passing of Paw Paw. As has Forgemagic, and Iforgeiron.com and other non-blacksmithing sites.
He was laid low by Metal Fume Fever. Here is what I found on the subject.
3-Respiratory System :
Most zinc salts irritate mucous membranes of the upper respiratory tract after inhalation.
a-Zinc chloride :
Inhalation of zinc chloride may cause :
-cough,
-dyspnea,
-adult respiratory distress syndrome, death, resulting from delayed pulmonary vascular fibrosis.
Ten deaths and 25 cases of non-fatal injury occurred among 70 persons exposed to high chloride concentrations of zinc chloride released from smoke generators. Of the 10 fatalities, a few died immediately or within a few hours with pulmonary edema, whereas those who survived longer developed bronchopneumonia. On dissolution of zinc chloride, both hydrocloric acid and zinc oxychloride are formed, contributing to the corrosive action.
b-Zinc oxide : Inhalation of freshly produced zinc oxide can produce metal fume fever.
From http://www.digitalfire.ab.ca/cermat/education/291.html
Basically what zinc does is, it causes the bodies natural defenses to go into overdrive. Thus the same as other heavy metal poisoning. This has been called in the past "Monday Morning Fever", "Brass Fever", "The Brass Shakes", "Foundry Flu", ect. . .
The flu-like symptoms do not generally cause alarm. But if you experience any flu-like symptoms after welding a plated material. "SEEK MEDICAL ATTENTION IMMEDIATELY!!" You may have been welding something that can only make you sick, or you may be dying and not even know it. Such platings can include things like cadmium. Cadmium when welded is extremely dangerous. Breathing the fumes WILL KILL YOU.
Jim Wilson was doing a project that made him sick. After the sickness he died. Jim Wilson's family lost a husband and father. The anvilfire group has lost a friend and mentor.
PLEASE be forewarned that welding plated material is extremely risky, and if you do not have the equipment for ventilation of a shop I would suggest that you do not do it.
Jason Duncan
PAW-PAW
I found this posted on another site. I think it's important enough to post here.
Welding Hazards
In confined spaces, welding can be much more dangerous. With less fresh air, toxic fumes and gases can be much stronger. Shielding gases, like argon, can displace the oxygen and kill you. These are some of the hazardous materials:
METALS
Stainless steel contains nickel and chromium. Nickel can cause asthma. Nickel and chromium can cause cancer. Chromium can cause sinus problems and "holes" between the nostrils.
Mild steel (red iron) and carbon steel contain manganese. Manganese can cause Parkinson's disease, which cripples the nerves and muscles.
Zinc in galvanized metal or in paint (on welded surfaces) can cause metal fume fever. It feels like the flu and goes away in a few hours or days after exposure ends.
COATINGS and RESIDUES
Lead (in some paints) can cause lead poisoning � headaches, sore muscles and joints, nausea, stomach cramps, irritability, memory loss, anemia, and kidney and nervous system damage. If lead dust goes home on work clothes/shoes, it can make your family sick, most of all your children.
Cadmium (in some paints and fillers) can cause kidney problems and cancer.
SOLVENTS
Welding through or near some solvents can produce phosgene, a poisonous gas. The gas can cause fluid in the lungs. You may not notice the problem until hours after you quit welding. But fluid in your lungs can kill you.
GASES
When carbon dioxide is used for shielding, carbon monoxide can form and kill you.
The welding arc can form ozone and nitrous oxides from the air. MIG and TIG welding make the most ozone, most of all when aluminum is welded. These fumes irritate the eyes, ear, nose, throat, and lungs and can damage the lungs.
Nitrous oxides can cause fluid in the lungs.
Paw Paw Wilson - Friday, 04/07/2000
MP
01/12/02
PETE F
01/14/02 Heating Galvanized Metal:
Be very careful of heating galvanized products. Burned zinc gives a toxic vapor that can make you VERY ill (even in a well vented shop). Before I knew of it I gave my self zinc fever (a form of heavy metal poisoning). It feels kind of like a bad flu. The effects are cumulative and once you have had it, if you are exposed YOU WILL GET IT AGAIN and a worse case. Welding galvanized metal and in some cases over heating brass along with brass grinding/sanding dust can also poison you. To be safe soak the part in muriatic acid overnight (to remove the zinc) and then then rinse with water. You may want to neutralize the acid with baking soda, then treat it as any other part.
MP
Zinc shakes:
I'll second MP on this. It is cumulative and really vivid! That is the short term effect, emphysema is the long term. Grimm stuff. I had my worst round of metal fume fever with projectile vomiting and #$# at #$# at # on a 15 second cycle for hours.
Pete F
ARRON
CISSELL More Real Life:
LEAD Pb, Plumbum
I would like to add one metal that is not listed above and is also very dangerous. Lead. I used to make fishing lures (Pro-Line if any of you have used them). When the Lead was at the correct temperature there was no problem as the OSHA approved ventilation was more then adequate.
The guys that did the pouring and molding wanted to get their numbers up. They turned up the heat on the Lead allowing them to pour an extra mold per casting cycle. This caused a heavy gas that OSHA simply called Lead Vapor. This resulted in four of our workers ending up in the hospital being treated for heavy metal poisoning. All but one fully recovered. My friend Alex Mendoza now suffers extreme daily headaches, joint pain, and memory problems. He also has had a major change in his overall demeanor and is now easily irritated at/by people, objects and situations. He is now disabled and has not been able to hold even a part time job to help make ends meet.
This same issue happened to another friend but not as severe. He works on high performance wheels. He was heating a specialy made wheel to change the bead angle when he �suddenly smelt something funny, got dizzy and dropped to the ground.� The hospital stated that it was heavy metal poisoning caused by Lead. After hearing this his boss inspected the wheels and found that Lead was used to fill and weight the bead. He had massive headaches for almost six months afterwards.
Please be careful around Lead especially when melting or casting. OSHA approved ventilation is not sufficient if lead vaporizes. This can cause serious and permanent health problems.
Arron Cissell - 06/02/2005
-GURU
NOTE: The day that Paw-Paw was brought home and hospitalized we had a letter from a mother about her son's zinc fume fever. He had been exposed at work welding in a meat packing plant. He had no training, no warning and the employer took no responsibility. Luckily he was young and strong and hopefully learned a valuable lesson.
About once a year I get a letter from a wife, mother or sister wanting to know what is making their men sick. Most often they have debilitating liver disease or mystery ailments after a life time working as a welder. Some have been employed in industry. Some have ben self employed. When the illness is caused by heavy metal poisoning there is no cure.
HEAVY METAL poisoning is almost always misdiagnosed and not treated. If you KNOW you have been exposed to possibly harmful metal dust, fumes or vapors, INSIST on being tested for metal poisoning and explain why.
THINK when you are working. Consider the repercussions. Be safe, live long.
-guru
iForge is an Andrew Hooper Production
HTML Copyright © 2005 Jock Dempsey, anvilfire.com - Blacksmithing and Metalworkers Reference for Metal Artists
Webmaster email: anvilfire webmaster
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #5
Myabe it will help,If you decide to just weld it off. I used a box fan or some fan set on as high as possible and blow the fumes away. In fact, I usually use the fan method for any welding
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #6
if convieniend I belt sand or grind it off.. or all else fails.. I blow it off with a torch. fialing htat. 6011 and don't stand over it inhailing. :)
( i don't weld alot of galvanized.. )
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #7
I've managed to weld EMT electrical pipe with galvanized coating by stripping it off with muriatic acid. I didnt' have to soak it over night, just about 20 seconds with a gallon jug of the stuff I got from Lowes.
Before I welded it, I stripped the zinc off, then left it outside to see if the end would rust - sure enough it did, and it got mighty nasty looking after a day or two. I've used muriatic ever since then - the key is dont breathe the smoke... just hold your breath - do it outside - or better yet get an appropriate respirator filter.
Hope this helps :)
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #8
Hope this helps :)
I have used muriatic acid to strip galvanized coatings and have gotten rust in an hour.
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #9
Rust started to form, but I got distracted for a couple days :)
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #10
Vinegar will do it as well, might take a day or two though. Also great for removing mill scale so I keep a gallon or two around and some tubs.
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #11
Not to dismiss safety, but there is a huge difference to prolonged and heavy occupational exposure, and zinc exposure from welding a piece of pipe or two once a year.
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #12
how to remove galvanized coating without grinding? - WeldingWeb - Welding forum for pros and enthusiasts
older TBN thread-
A Case study
May 13, 2005
JOCK
JASON
a-Zinc chloride :
-cough,
-dyspnea,
Jason Duncan
PAW-PAW
Welding Hazards
METALS
SOLVENTS
GASES
MP
01/12/02
PETE F
MP
Zinc shakes:
Pete F
ARRON
LEAD Pb, Plumbum
-GURU
-guru
HTML Copyright ゥ 2005 Jock Dempsey, anvilfire.com - Blacksmithing and Metalworkers Reference for Metal Artists
Evidense suggests that metal fume fever may never lead to death
http://www.aws.org/technical/facts/FACT-25.pdf
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #13
yup.
for the averge guy that needs to weld a bit of gv pipe onto something and just grinds it off and goes and doesn't stand over the puddle huffing it while he makes that 20 second weld out in his barnyard in the open air... .. that's a big difference than someone who did production work working on gv parts.. etc..
A continued thanks to everyones thoughts...... and discussion.
Obviously, the case of Paw Paw above IS Extreme... He already had health/lung issues and was (smelting) a large amount
of galvanized pipe in an enclosed oven no place for residue to go.. The point is somewhere between a simple no biggy one time or infrequent weld on galvanized to, welding miles of it a day with no protection, different people can have different reactions to different amounts of exposure.
Like Peanut or bee sting allergies.... someone can eat peanut related food all day long or get stung by numerous bees without any adverse effect whatsoever, or one bite or even smell of peanuts or one sting could kill someone highly allergic or affected, if not treated immediately.
Someone with asthma, might not have a threshold to zinc fumes, as someone with no breathing issues.
I asked the question because we tend to just say (or believe) 'it's just a little bit"! I had always heard about it "not being safe to
breath the fumes of galvanized metal. There were never any qualifiers to that statement. As stated in the aws report
most are exposed in the workplace, and rates of exposure should be monitored, but if we were to do alot of farm fab, (using galv. metal, brazing, ect. ) most people I know don't have toxicity level monitors as one of their shop/ farm tools. How do we gauge what OSHA permissible limits are or mean?
(I saw an article yesterday, about the military doing Nuclear tests, in one case, with 5 military officers standing at ground ZERO of a test explosion, in Nevada in the 1950's ) I wonder what OSHA would have said about those exposure limits?
Most of us probably are welding indoors and how many would run to grab a fan (?) just to air out the shop area while doing one or two welds for a moment,( or even bigger welding endeavours) especially on a wet, cold day or night. How many would grab a respirator just to be cautious?
I know I've never tried to jamb my respirator under the welding hood. Haven't bothered digging out the fan either.
We probably would just leave for a bit and say (think) "well that should be good enough, everything looks clear" five minutes later.
Probably is, but do we really know?
Also always wondered if the weld could be weaker due to any zinc contamination.... that's partially why I haven't bothered much with it either. But figured if remove it (zinc) entirely ( I'll have to try muriatic acid) that would solve two issues.
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #15
Btw. I don't know how dangerous it is but the fumes that come off when removing galvanizing with acid are pretty wild. I got a wiff once when doing some washers and it bout knocked me down.
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #16
Wow! Maybe my trailer modifications kept getting delayed for a reason! I have a galvanized boat trailer I've been wanting to convert to a flat trailer by welding rails and uprights and adding a mesh floor to it for a couple of years now, but so many "Honey Doo's" kept getting in the way. I COULD'A GOT KILLED!
Can I safely grind the trailer where I want to weld the angles without a respirator? I don't like the acid idea because I'll never feel like I got it all rinsed off properly...and I haven't liked acid since the early 70's....
Any problems painting over it when I'm done? It's an old trailer and well weathered, but not rusted. I was thinking about scuffing it with a wire wheel or pad sander and hitting it with some paint. (driveway type paint job)
Any advice is always appreciated.
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #17
A couple of thoughts.
Yes zinc in the weld area will weaken the weld. If possible get rid of it.
If you have been heating or welding on zinc coated items and you get to much of the fumes you can taste them.
If you get a bad taste, you have had too much. Stop
Drink all the Milk that you can stand. It will pick up some of the zinc poisoning and help clean your system.
Hope that helps.
The way I was thinking of using the acid, IF I try it, is to dip the end of
(loose, single pieces) the pipe into
a supported container (out in open air) just to strip ends for welding. But as I remember treating swimming pools years ago, the acid DID have a very strong (noxious) smell.
Your trailer or anything assembled, I would think, probably easier, and better to grind on the frame rails, than to brush and dripping the acid.
As for painting, I know there are formulations of paint for galvanized surfaces. some paints work (adhere) better than others.
Typically there are special (zinc based I believe) primers put on surfaces under the topcoat (color), there probably are paints, that can be directly applied to older weathered galvanized surfaces.
Here is a link to check out. look under "weathered galvanized coating"
Painting Hot-Dip Galvanized Steel |Cleaning, Paint Selection, Surface Preparation, Duplex Systems
hope this helps
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #19
All good information. Thanks to all and to this site for being there.
   / ANY way to REMOVE , Galvanized coating on steel (pipe) 2 make safe 2 weld #20
Weld in a well ventilated area, and drink MILK, lots of it. The calcium from the milk retards the absorbtion of zinc into the bloodstream and helps prevent poisoning.
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A61307)
2024 Kubota...
2014 Ford Transit Connect XLT Passenger Van (A59230)
2014 Ford Transit...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A59231)
2009 Mariah SC23...
2013 CATERPILLAR 336EL EXCAVATOR (A60429)
2013 CATERPILLAR...
