Metal Building
/ Metal Building #1
enterprisebbc
Ct
2008 CK35 Kioti
IMGP2302.jpgI have finaly finished a home for my equipment and tractor. I would like to heat it a few times during the winter for maintainence etc. I'm trying to do this for not much $. I have an old wood stove that would work just fine but I've been told that I need insulated pipe all the way through to the outside because of creasolt build. I have black pipe and 1 insulated piece that could go through the side of the building but elbows on the outside are a no no. So I must go straight through the roof. How in the **** can I go through the roof which is corrigated and keep it waterproof so it wont leak? If I use insulated pipe all the way up and go into the side and then up it would be very expensive. Sooo, I could also just use a convection LP heater $130, 40lb tank $89 and be done with it and put the stove on Craigs List. WTF to do?
/ Metal Building #2
I would highly suggest that you run straight up through the roof. They do make flashing specifically for flashing chimneys against corrugated metal roofing. Do a google search on "corrugated roofing flashing for chimney pipe" and there are some good forum threads with ideas. An alternative is to run inside as far up as possible (maintain proper clearance) and then elbow out to the outside, and use a T with cleanout on the bottom to go up above the roof. These methods will minimize the amount of expensive smoke pipe you need. Others will chime in here I'm sure.
Make sure you get the chimney top into clean air, meaning that you are at least 2' higher than anything within a 10' radius. Don't mess around with CO, do the chimney right.
Joe
/ Metal Building
Thanks. Didnt know they made such a thing. I'm on it Randy
/ Metal Building #4
I ran a 75000 btu LB White hog heater from a 100 lb propane tank for a few years in an insulated building. It was just used a couple hours a day for about 3 days a week during the coldest part of the winter. It was cheap and easy but it sure did make a lot of moisture in the building. A lot of mornings the over head doors were frozen down.
/ Metal Building #5
Duravent makes a complete thru the wall kit with all the parts needed. I put one in the back wall of my barn, most of the pipe is inside and is standard single wall black stovepipe, only a short external chimney. It as a built in piece in the bottom that pulls out to clean the chimney
Informational Lot - Financing (A63688)
Informational Lot...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
2002 Jeep Wrangler (A64127)
2002 Jeep Wrangler...
Jitter Bug (A62613)
Jitter Bug (A62613)
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65583)
New/Unused AGT...
