Members home made attachments / improvements
   / Members home made attachments / improvements
OK, two more pictures.
Basically the design is two square tubes welded onto an attachment plate. Cross members provide a rigid frame and are lined up with rungs to attach with u-bolts. There are also size dogs made out of bent angle iron to provide support under the ladder rungs when it transitions from the hanging state (carried by u-bolts) to the upright state.
The guy who did the welding suggested the stuts and the flat bars going forward/backward to increase the rigidity and take tension off of the leading weld on the attachment plate. I can say this was a great idea given how much flex those long ladders have anyway! Lots of bounce when driving it around...
I can leave the carrier attached when the ladder is in use, and can detach the whole thing without undoing the u-bolts. The only trick is that the ladder has to be at least about 30 degrees up at one end to detach/attach, as the PT loader cannot curl its attachment plate forward past horizontal/down.
Very innovative Kent I like it.. :thumbsup:
   / Members home made attachments / improvements #262
Tim_in_CT said:
That is pretty cool, but not $594 cool. :eek:
Plus, I suspect you would lose some stability when you chucked it up in the PT 2" receiver.
I strongly considered fabbing something like that when I was cleaning my gutters at the top of a 24' ladder last fall. Instead, I just made a 15' PVC wand that attaches to my leaf blower, and finished the job from the ground.
Lets see that wand and how you attached it to your blower
   / Members home made attachments / improvements #263
image.jpgimage.jpg My counterweight and brush forks. I use the forks probably 90% of the time, they are light enough I can pick them up with one hand and the abuse they take really surprised me. So far I've only bent the tines a little but that was using them as a pry bar with the loader to free up some frozen logs.
See my old thread is still here as well.. May have to get another one of these little Pt monsters soon.
Power Trac wants close to $700.00 delivered for a new Rop's.
I figure since I have an old tractor anyway I will make my own and cut that price in half.. Figured I may as well put it under this old thread I started years ago. My question to any of you has anyone already done this ? And would one of you be nice enough to measure out from the side mount of your Rop's to the edge of the outer bar. I would appreciate it.. I was thinking around 6 inches extended out on each side. Thanks in advance ..
   / Members home made attachments / improvements #267
mine is welded right to the frame.....so it only extends the width of the 2" pipe on each side........Jack
Thanks Jack !
   / Members home made attachments / improvements #269
Not at home right now... don't know if this picture from the front will help you or not, but it can't hurt! :D
Yes it does on the angle thanks ..
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2015 Ford F-350 Cab and Chassis Truck (A56858)
2015 Ford F-350...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
36FT. B-Tek Centurion 100 Ton Digital Modular Commercial Truck Scale (A56858)
36FT. B-Tek...
2013 BMW 328i Sedan (A56859)
2013 BMW 328i...
