MECHRON 2200 looking to add tail lights and brakes
   / MECHRON 2200 looking to add tail lights and brakes #1
kwg
Addison WI
2012 Kiotie CK35 HST
Does anyone know which wires are for brake lights and tail lights?
   / MECHRON 2200 looking to add tail lights and brakes #2
Doesn’t it come with brake/tail lights?
Mine is an older one that didn't have them when I bought it.. If it already had them I wouldn't need to know where the wiring is located.
   / MECHRON 2200 looking to add tail lights and brakes #4
That kind of info would’ve been helpful in your initial request. No need to be pissy….
I didn't mean to be "pissy". I guess I didn't feel I needed to explain why my machine doesn't have the lights. I just thought I could ask where and if there are wires already on machine to hook up to. I found two wires under the front hood that seem to be good for the tail lights but nothing for the brake lights. I guess I read your response thinking you thought the lights were already installed and I just didn't notice them.
   / MECHRON 2200 looking to add tail lights and brakes #6
I have seen a tail light and turn signal kit on ebay that plugs into the factory harness. I don't think there are any wires unless you had that kit installed previously.
ill look into that. Thanks
   / MECHRON 2200 looking to add tail lights and brakes #8
I bought the kit from dealer as installed myself. The wiring harness was hard to find but we're there. The kit had turn signal and horn.
  • Good Post
Reactions: kwg
I ordered a brake switch off E bay for $27. I'm just going to find a "hot" maybe off the headlights and go through a 12VDC relay for the tail lights
2022 Weber MT CF2A Plate Compactor (A55851)
2022 Weber MT CF2A...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2014 Ford Fusion SE Sedan (A55853)
2014 Ford Fusion...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
Willmar 4550 Wrangler Articulating Loader (A55314)
Willmar 4550...
