MECHRON 2200 looking to add tail lights and brakes
   / MECHRON 2200 looking to add tail lights and brakes #1
kwg
Addison WI
2012 Kiotie CK35 HST
Does anyone know which wires are for brake lights and tail lights?
   / MECHRON 2200 looking to add tail lights and brakes #2
Doesn’t it come with brake/tail lights?
Mine is an older one that didn't have them when I bought it.. If it already had them I wouldn't need to know where the wiring is located.
   / MECHRON 2200 looking to add tail lights and brakes #4
That kind of info would’ve been helpful in your initial request. No need to be pissy….
I didn't mean to be "pissy". I guess I didn't feel I needed to explain why my machine doesn't have the lights. I just thought I could ask where and if there are wires already on machine to hook up to. I found two wires under the front hood that seem to be good for the tail lights but nothing for the brake lights. I guess I read your response thinking you thought the lights were already installed and I just didn't notice them.
   / MECHRON 2200 looking to add tail lights and brakes #6
I have seen a tail light and turn signal kit on ebay that plugs into the factory harness. I don't think there are any wires unless you had that kit installed previously.
ill look into that. Thanks
   / MECHRON 2200 looking to add tail lights and brakes #8
I bought the kit from dealer as installed myself. The wiring harness was hard to find but we're there. The kit had turn signal and horn.
  • Good Post
Reactions: kwg
I ordered a brake switch off E bay for $27. I'm just going to find a "hot" maybe off the headlights and go through a 12VDC relay for the tail lights
2013 PRIME TIME RV LACROSSE (A58214)
2013 PRIME TIME RV...
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
NEW Wolverine 84in High Capacity Pusher (A59000)
NEW Wolverine 84in...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
