Measuring/calculating PTO speed (not PTO speed = Machine speed / implement speed)
   / Measuring/calculating PTO speed (not PTO speed = Machine speed / implement speed) #1
OldNick
Perth WA
Massey 135
I DAGS and searched the forum for PTO speed etc.
So. I have a Hinomoto N279 32HP tractor. Maybe I bought badly as it does not even have its own section here :(
However.. The N279 has a 4 gear/speed PTO. I know the flail mower I have bought requires a 540 RPM PTO speed. But I do not know for the N279 what PTO speed results from what engine speed in each PTO gear. The Tacho has no indication of PTO speed for each PTO gear.
So how do I measure the PTO speed? I tried writing on a spline with liquid paper. But 540 RPM is what.... 9 per second. Try counting that.
To add to that, the 4 PTO gears do not make sense to me: they do not go 1=slowest 2=a bit faster...etc. They seem to duck and dive, based purely on non-measure obs.
Or do I just wing it, going as high-gear as I can without labouring, running at 1500 RPM of the 200RPM of the N279, and yet getting a decent thrashing? :)
I understand that the whole thing revolves around also looking at Forward Movement Speed and is all a balancing trick. But I would like to know the figures as a starting point.
   / Measuring/calculating PTO speed (not PTO speed = Machine speed / implement speed) #3
   / Measuring/calculating PTO speed (not PTO speed = Machine speed / implement speed) #4
Geeze - that makes life easy. Not really that expensive either.
   / Measuring/calculating PTO speed (not PTO speed = Machine speed / implement speed) #5
^^^^Yup.....get a tach if you dont have an owners manual.
But an unfamiliar machine to you....I'd do some web searching and see if you can find an operators manual
   / Measuring/calculating PTO speed (not PTO speed = Machine speed / implement speed) #6
The tachometer should have an indicator that shows what engine speed is needed for 540 pto rpm. This one is at 2500 engine rpm:
   / Measuring/calculating PTO speed (not PTO speed = Machine speed / implement speed) #7
In this case, it doesn't have any marks. It may be written on a sticker somewhere though.
Hinomoto N279 Dash
   / Measuring/calculating PTO speed (not PTO speed = Machine speed / implement speed) #8
One site said rated power was at 2600rpm and governed speed was 2800rpm. I'm thinking that 540 pto speed will be near 2500 rpm.
OK. That laser thingy looks cheap enough to give a go without killing my bank balance. Even at the USD Aud exchange rate, I have a couple of jobs for it, right now. Thank you
Well I certainly do not want to run my engine at 2500! Anyway does that have anything to do with a 4-speed PTO, or refer to my question?
UNUSED FUTURE MINI PALLET FORKS (A57193)
UNUSED FUTURE MINI...
2022 Case IH 8250 Axial-Flow Combine (A53485)
2022 Case IH 8250...
2016 Ford F-150 4x4 Pickup Truck (A55852)
2016 Ford F-150...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
2006 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A52707)
2006 CATERPILLAR...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
