Mazzotti back hoe attachment?
/ Mazzotti back hoe attachment? #1
Scott D
Hello. I was just down at my dealer and we were talking about using a back-hoe attachment on my ford 1910 tractor. He had an older (looks like a build date of 1986 on it) Mazzotti brand hoe attach. It runs a pump off the PTO and hangs suspended off the 3 point. It has two hydraulic feet that you lower to stabilize the tractor when digging and you sit on a seat facing the hoe when operating. It's got a little 1 foot wide toothed bucket. I'm needing a small hoe, and was wondering if anyone else has used this brand? I'm not trying to remove stumps, just dig some holes for trees, landscaping, fish ponds etc. I know it will never be as good as a dedicated hoe but for $2500 it might do the trick? I just don't want to damage my tractor nor buy a "pig in a poke". Any thoughts or experiences would be welcome. The 1910 generates about 27-30hp I believe. Thx .
/ Mazzotti back hoe attachment? #2
Don't know anything about a Mazzotti hoe. Just look at the components and how it is made. Look at the clearance underneath also. I had a 3-point hoe, it dug to 7' and was quite handy. I had it on a larger tractor with a beefier rear end so didn't run the risk (as much) of breaking the housing. I sold mine used for $2500 and upgraded to a larger unit with a 4-point mount. If you keep yourself within the capabilities of the unit you should be fine. How deep does it dig and does it have swing "cylinders"?
/ Mazzotti back hoe attachment? #3
I have that exact Mazzotti hoe & got mine used as well. It is a STOUT piece. I was using it on the back of a 50HP Same' tractor and it wiggled the tractor around when I dug up some palmetto bushes. I only see one drawback from using it - the leg-room is tight. You CANNOT safely stick your feet in front of the footholds. I need more legroom, and am considering making it a frame-mounted piece and getting a dedicated tractor for it. That way I could dig w/the hoe and still have the 3-pt stuff available on my Same'. I'd give myself some additional room and move the seat back away from the controls so it is comfortable. You can download a PDF copy of the Owners manual.
I know I need more practice with it, but need the 3-pt for other things right now.
I don't think you'd be disappointed with it... Like I said - its stout!
49T&C
Thx guys, yes I saw two cylinders on the bottom for moving the hoe left & right. And yes, I agree it does look pretty stout and it is way to heavy for one man to lift or manouver around so setting on a dedicated rack I think will be critical. There is no filter for the hydraulics on the unit but I suppose the amount of use it gets makes that non-critical. So is $2500 the going freight for a small hoe attach that is 25 years old?
2019 KUBOTA SVL75-2 SKID STEER (A65053)
2019 KUBOTA...
2015 Volvo 85160 4yd. Loader Bucket Attachment (A64553)
2015 Volvo 85160...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
