Buying Advice Maybe going from Kubota to Mahindra.
   / Maybe going from Kubota to Mahindra. #1
Block Head
Hey guys,
I have a [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] B2650 hat that has 250-300 hrs on it. It’s a great tractor and perfect for around our little farm/welding and machine shop. I bought a piece of land 10-acres that needs to be cleared and I’d like a little bit bigger tractor. I’m thinking about a 40ish hp Mahindra and I’m wondering if you folks like your Mahindra tractor? I know they are heavier then the [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] tractors and I wonder if that goes to stronger more durable? I’ve had 4 Kubotas and all have been great machines. I’m thinking about changing brands not because I don’t like my [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] I just would like to try another brand and I hear Mahindra is a good one to try. Also what should I ask for my 2650? Great shape! No dents or scratches.
Thanks
Bulldog
KB2ZVP
   / Maybe going from Kubota to Mahindra. #2
I'm brand loyal. My suggestion is to buy a bigger M or MX series Kubita in the 50-60 hp. You already know [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] is a good brand, why change now?
   / Maybe going from Kubota to Mahindra. #3
I have 2 mahindras , an older 2810 with shuttle shift and a newer 2538 hst really like both tractors and have had good luck with both, My buddy has an Ls xr4140 and it is a really nice tractor with lots of standard features. I would look at all available tractors in your area before deciding, If they let you try them out all the better,
   / Maybe going from Kubota to Mahindra. #4
You probably can't go wrong with either brand. The Mahindra is definitely heavier, and has a bigger bucket that will allow you do more things faster. I've had mine for 6 years+ now, no problems, and it works like a beast. (Well over 1700 hours) My neighbor had the same [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] you do, and frankly, mine ran rings around his. Lifted more, pulled more, etc. And the bonus is (or was when I bought mine) no DEF, or regen procedures to go thru.
My other neighbor looked at [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] and Mahindra (didn't want a Deere for whatever reason) and said he like the Mahindra far better, and bought it.
I looked at the [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] & Deere before I bought the Mahindra, and there are a lot of little features that you'll appreciate after owning it for awhile.
But to each his own. Good luck with your choice.
   / Maybe going from Kubota to Mahindra. #5
Love my Mahindra. 2nd one. Would definitely buy a third.
A lot more tractor for less money.
   / Maybe going from Kubota to Mahindra. #6
Hey guys,
I have a [AFFILIATE='1, nofollow=true, newwindow=true, title="Kubota"']Kubota[/AFFILIATE] B2650 hat that has 250-300 hrs on it. It’s a great tractor and perfect for around our little farm/welding and machine shop. I bought a piece of land 10-acres that needs to be cleared and I’d like a little bit bigger tractor. I’m thinking about a 40ish hp Mahindra and I’m wondering if you folks like your Mahindra tractor? I know they are heavier then the [AFFILIATE='1, nofollow=true, newwindow=true, title="Kubota"']Kubota[/AFFILIATE] tractors and I wonder if that goes to stronger more durable? I’ve had 4 Kubotas and all have been great machines. I’m thinking about changing brands not because I don’t like my [AFFILIATE='1, nofollow=true, newwindow=true, title="Kubota"']Kubota[/AFFILIATE] I just would like to try another brand and I hear Mahindra is a good one to try. Also what should I ask for my 2650? Great shape! No dents or scratches.
Thanks
Bulldog
KB2ZVP
I would look at ALL BRANDS before you make a decision ..
   / Maybe going from Kubota to Mahindra. #7
I have no direct experience with either (I have that evil green machine :LOL: ) but one neighbor has a [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] and another has a Mahindra. The [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] works hard and never stops. The Mahindra mostly lives on a trailer going to, or coming back from, the dealer for repairs.
Maybe he got a bad one, or maybe he's just rough on it, but given what I've seen with these two, I'd go with the Kubota.
   / Maybe going from Kubota to Mahindra. #8
I ran a couple different mahindra tractors pulling a drag at a tractor pull. If someone gave me any one of those tractors I’d sell them and buy something else.
   / Maybe going from Kubota to Mahindra. #9
Just buy some floor dry for the leaks under the Mahindra.
   / Maybe going from Kubota to Mahindra. #10
My view of Mahindra is "it depends". Since they have so many manufacturers making various models for them, the quality, features and performance varies more than most.
I think dealers of any brand persuasion really vary from place to place. I've had really bad luck with the JD dealers, but I am 100% sure there are good ones out there.
   / Maybe going from Kubota to Mahindra. #12
For small farms, it is true that [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]kubota[/AFFILIATE] is good, but for larger farms, I would not buy it unless for transport
   / Maybe going from Kubota to Mahindra. #14
I hear good things about Mahindra, and I hear bad things about Mahindra. More than any other brand, I would make sure that I had a darned good dealer. You also might get more feedback from the posters here who have the particular tractor you are considering.
That's why I bought a Kubota... I needed something quickly and knew that they've only made one bad model.
   / Maybe going from Kubota to Mahindra. #15
I will second that thought, i love my Mahindra 5145 and would buy another, but it is the best tractor for me not necessarily you. Mahindra is a good brand IMO and built like a tank.
   / Maybe going from Kubota to Mahindra. #16
Not that you asked, and I have no idea what the 10 acre plot needs, but I'm imagining a heavily wooded property. With that, I think most compact tractors will be pretty much useless. If that's the case, would avoid selling right away, have the lot cleared by a pro, then evaluate what you need to do. You may even decide to do it yourself and buy an old industrial backhoe and sell it afterward. Lots of options.
   / Maybe going from Kubota to Mahindra. #17
We got two fairly new dealers in the town closest to me. An LS dealer and a Mahindra dealer.
All the plow contractors and landscape businesses bought them because they were cheaper. I saw lots of broken front axles and other issues. They all run [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] and Deere now for what it's worth.
I'd have to have an LS or Mahindra GIVEN to me to try for a thousand hours or so before I got the confidence to buy one.
   / Maybe going from Kubota to Mahindra. #18
I have several friends with Mahindras. Machines are good. Parts availability was a problem
Andy
   / Maybe going from Kubota to Mahindra. #19
all the plow contractors and landscape businesses bought them
Yet this is the difference. Those tractors do more in a year than most of us will use them in 20. The private owner is also much less likely to abuse them.
   / Maybe going from Kubota to Mahindra. #20
I have had two Mahindra tractors in my business. They got used hard with no issues. I would not get all hyped on how much they can lift though. Just because it can does not mean it should. You need major rear ballast to get the loader to max lift. I think customer service is probably better with [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] as I have a couple of svl machines and they have been great also. If you love your [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] why would you chance it and change?
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2016 VERMEER PD10 PILE DRIVER (A60429)
2016 VERMEER PD10...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2007 CATERPILLAR D6N HIGH TRACK CRAWLER DOZER (A60429)
2007 CATERPILLAR...
