May get a new chipper
/ May get a new chipper #81
Well..... Good news, my wife thinks we need a Woodland Mills WC-68 so I ordered one today! :) :cool2:
Ha, funny thing, my wife agreed also. Now I just have to talk myself into letting go of the cash.
/ May get a new chipper #82
Please keep us updated on that........I will need to do that also!
Now I need to sell my old Bearcat 70554 Chipper/Shredder!
I'll probably keep mine, it has the blower.
Any idea what they are worth?
/ May get a new chipper #83
I've been thinking about a chipper for some time now, considering the WC68, WC88, and Woodmaxx wm-8h.
Similar to most of the comments, I don't plan on chipping oak bigger than 4" as that's firewood (my woodbox has 2"-8" in it as we speak but if I have a chipper I'll probably chip more than I take to the burn pile now), but lots of my stuff isn't straight - mostly scrub oak that goes every which way but straight, so I'm leaning to the full 8" square chutes.
My main concern is PTO hp; my tractor's apparently got 29hp, which is below the suggested range for those chippers, but I'm not going to chip big stuff at speed... should be ok? Also the next tractor will be bigger haha!
/ May get a new chipper #84
I see a brand new Bearcat SC 5540 (same as 70554) without the blower is about $3000. (< crazy?) Mine does not have the blower.
I just took all the guards off, greased it, installed brand new knives and PTO shaft. It's ready to work.
Thinking of trying to sell it for $1000. What do you guys think? :confused3:
/ May get a new chipper #85
See post #28 above (page 3) I empathize; the limbs on my oaks are wind-pruned. The leader was broken off and a lateral became the new main stem, often several times to produce a zig-zag. Made for a lot more cuts and a lot more "bend overs" to pick up and feed short branches. The number of handlings greatly influenced my decision to chip "firewood".
Flywheel weight is important. A heavier flywheel stores more energy and may power through "big" stuff before loosing momentum. I have a Salsco model 627, nominally 6", 7" opening, 210 lb. flywheel, driven by 32 PTO HP. It will bog down 4-5' into a 6" eastern white pine log, and I have stalled it. You will soon learn what your chipper will handle--green and pliable, seasoned and hard, old and punky. I know my machine's vibration will disintegrate the rotten sapwood of an oversized pine and feed and chip the still sound heartwood. After the laborious process of un-jamming a clog in the throat, you will also learn how long or sharp a bend in a crook, how stout a stub of a branch, etc. will not pass though the chipper.
/ May get a new chipper #86
I bought my secondhand Bearcat 7 years ago at a Deere dealer a couple towns over for $1200 plus tax. Near as I could gather, it was about 4 years old at the time and used only one summer by the janitors at a nearby school. I wondered if I was the only one to look at it for a while because he was very willing to negotiate a lower price, they had it priced around $1500.
/ May get a new chipper #87
I bought mine used 6 years ago, used it a few times that year but It wore me out feeding it. I had a lot of brush to clean up and ended up burning it. The previous owner cut the PTO shaft too short and I ordered new chipper knives for it, but I parked it the corner of the garage and never got around to fixing it until now, so it hasn't been used in 5 years. Should work pretty good now with new knives, new PTO shaft, and new belts!
I'm pretty excited about my new Woodland Mills WC 68 coming!
Getting ready to go out and plow snow now. :(
/ May get a new chipper #88
My tractor's got 32hp at the PTO. When I chip larger stuff I have to slow the feed way down and/or stop and start the feed to keep the tractor from bogging down. It depends quite a bit on the species. Coast live oak is the hardest to chip since it's hard dense wood and grows crooked. Fir is so much easier.
I was frustrated with the hydraulic feed control on my 8H. It was either full on or a crawl and very difficult to set to anything else... the functional range of the adjuster was very narrow. Resarching the numbers stamped on it I found that it's a 20 gpm unit. I talked to Woodmaxx and they told me the system is 3 gpm. Well there's your problem! I replaced it with a US made direct replacement valve that's 5 gpm, and that gave me a useful adjuster. Since it looks like the Chinese valves are all 20 gpm, I would not be surprised if Woodland Mills units have the same problem.
The Woodland Mills chippers come inside a box but with a metal reinforcement frame inside the box.
Here are pictures of what we made with the metal frame. The top was made into a table. The bottom was made into a dolly to sit the idle chipper onto to allow rolling it around. Cost me $70 for 300 # metal castors from TSC and $100 to get them welded.
You can also see the 2 by underneath the front of the bush hog with steel casters underneath it.
Ralph
/ May get a new chipper #92
The table and skid were good practical ideas. Nice.
My control arm was too easily popping into neutral when shredding with chipper downhill, e.g. weight of arm then makes it easier to pop into neutral. I followed their instructions to tighten up the action via a 6 mm allen screw locked via a 22 mm nut at the bottom of the hydraulic stuff. Turned it 1/2 turn tighter. Got to finally use it a tad this afternoon before the rains came again and determined the action is too stiff now. Will back off 1/4 turn. Someone else on the Facebook WM site mentioned that he ran his 1/4 turn tighter than factory setting. Got a reply back from WM tech service, and they say 1/4 to 1/2 turn is generally "it". The factory setting gives almost seamless action among reverse-neutral-forward. The 1/2 turn made that action quite noticeable.
Ralph
Got it on the dolly now. Should have had them weld another metal piece or two across the hole in that bottom structure. In shipment, they had a couple upward pieces of metal to keep the unit from slipping into the hole, but these are not consistent with use of it as a dolly; had the welder cut them off. I'll get a piece of plywood and a couple pieces of 1 by to screw to and put plywood over the hole.
Ralph
/ May get a new chipper #95
Ralph
I turned mine in a 1/4 turn also, worked much better!
/ May get a new chipper #96
Finally got a good gap without snow so had a chance to mount the WC88 and tomorrow will give it a functional check in the woods. With 60 hp at the PTO it should not have any problem.
Nice machine for your big tractor. The WC46's 510# weight is very noticeable on the slope behind the house. The 2025R would not be safe with a bigger machine.
I bought a 4x4 piece of 15/32" plywood and cut it to fit into the dolly. Covers the whole inside part and that hole.
Ralph
Year: 2016 Make: Jeep Model: Renegade Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 117,889 (A61569)
Year: 2016 Make...
43023 (A59228)
43023 (A59228)
VAC PUMP MUFFLERS QTY 5 (A60736)
VAC PUMP MUFFLERS...
2018 GENIE GTH-1256 (A60736)
2018 GENIE...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
(INOP) 2019 FREIGHTLINER COMPACTOR TRUCK (A59823)
(INOP) 2019...
