Oil & Fuel Max25 fuel shutoff
   / Max25 fuel shutoff #1
KB1JIM
Penobscot Cty, ME
Mahindra Max25
My 2014 Max25 has no fuel shutoff that I can find. How do other owners deal with this when servicing the fuel filter? My dealer skipped town and the entire state of Maine has no Mahindra dealer that I'm aware of.
   / Max25 fuel shutoff #2
Put a shutoff valve inline between the filter and the tank. That's been done plenty of times.
Hint: Pinch the hose near the tank before cutting...
-R
Thank you. Would you know what size?
Thank you. Mahindra should fix their online dealer finder.
   / Max25 fuel shutoff #10
The fuel shut off is built into the filter housing, as you unscrew the filter bowl it will shut off.
There is a plunger that the bowl pushes on to turn the fuel on and when taken off it shuts off.
And when replacing the filter make sure you either replace the small oring in the center of the filter or swap it from the old filter.
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53472)
2017 Yale GLC050VX...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
