Oil & Fuel Max25 fuel shutoff
/ Max25 fuel shutoff #1
KB1JIM
Member
Penobscot Cty, ME
Mahindra Max25
My 2014 Max25 has no fuel shutoff that I can find. How do other owners deal with this when servicing the fuel filter? My dealer skipped town and the entire state of Maine has no Mahindra dealer that I'm aware of.
/ Max25 fuel shutoff #2
Put a shutoff valve inline between the filter and the tank. That's been done plenty of times.
Hint: Pinch the hose near the tank before cutting...
-R
Thank you. Mahindra should fix their online dealer finder.
/ Max25 fuel shutoff #10
The fuel shut off is built into the filter housing, as you unscrew the filter bowl it will shut off.
There is a plunger that the bowl pushes on to turn the fuel on and when taken off it shuts off.
And when replacing the filter make sure you either replace the small oring in the center of the filter or swap it from the old filter.
2009 FONTAINE FLATBED (A60736)
2009 FONTAINE...
2004 FRAC TANK 500BBL WHEELED (A60736)
2004 FRAC TANK...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2012 SOUTHERN 130 BBL VACUUM TRAILER (A60736)
2012 SOUTHERN 130...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
