Max RPMS Tc45d
   / Max RPMS Tc45d #1
missesalot
Brockport NY
tc45d
As you guys can tell I'm spending a lot more time using and learning about my tc45d. thanks alot for all the replies on my other threads. I've noticed in the data for this tractor that it says power and rpm ratings are measured at either 2400 or 2600 rpms. My tractor seems to max out at about 2200 rpms at full throttle. Does that mean i need to adjust something or is that normal? Why would the ratings be based on an RPM level the machine doesn't push?
thanks
   / Max RPMS Tc45d #4
Check your throttle cable length to see if it is long enough. It may not be opening the throttle all the way.
   / Max RPMS Tc45d
Is that an adjustment on the engine side?
NEW Fork Extensions (A53002)
NEW Fork...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
