Max RPMS Tc45d
   / Max RPMS Tc45d #1
missesalot
Brockport NY
tc45d
As you guys can tell I'm spending a lot more time using and learning about my tc45d. thanks alot for all the replies on my other threads. I've noticed in the data for this tractor that it says power and rpm ratings are measured at either 2400 or 2600 rpms. My tractor seems to max out at about 2200 rpms at full throttle. Does that mean i need to adjust something or is that normal? Why would the ratings be based on an RPM level the machine doesn't push?
thanks
   / Max RPMS Tc45d #4
Check your throttle cable length to see if it is long enough. It may not be opening the throttle all the way.
   / Max RPMS Tc45d
Is that an adjustment on the engine side?
Krause Dominator 4850-18ft (A56435)
Krause Dominator...
cummins generator (A56857)
cummins generator...
Honda ES 6500 Generator (A55973)
Honda ES 6500...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
202483 (A54757)
202483 (A54757)
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
