Max RPMS Tc45d
   / Max RPMS Tc45d #1
missesalot
Bronze Member
Brockport NY
tc45d
As you guys can tell I'm spending a lot more time using and learning about my tc45d. thanks alot for all the replies on my other threads. I've noticed in the data for this tractor that it says power and rpm ratings are measured at either 2400 or 2600 rpms. My tractor seems to max out at about 2200 rpms at full throttle. Does that mean i need to adjust something or is that normal? Why would the ratings be based on an RPM level the machine doesn't push?
thanks
   / Max RPMS Tc45d #4
Check your throttle cable length to see if it is long enough. It may not be opening the throttle all the way.
   / Max RPMS Tc45d
Is that an adjustment on the engine side?
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
BUYERS PREMIUM & PAYMENT TERMS (A52576)
BUYERS PREMIUM &...
500BBL WHEELED FRAC TANK (A52472)
500BBL WHEELED...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
New 20ft 5/16in G70 Tie Down Chain (A50323)
New 20ft 5/16in...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
