Loader max loader lift comparison
   / max loader lift comparison #11
Good call there, ye with eagle eyes! Old foggy lenses here saw 2630, which is a 'B', not 2360, a 'BX'. The LA403 loader for the 'B' is actually more comparable to the TYM specs, but I still think lifting 1,000 lb way up high with a 2,000 lb tractor is a bit sporty.
Snoozer, if you are still checking here at TBN, be aware Kubota has both a 2360 and a 2630 model in its current lineup. The BX2360 is a smaller tractor than the TYM. Dunno if it's priced similarly, but considering the brands, that sounds very plausible. But the comparison is apples and oranges. The B2630 is a bigger unit, probably more comparable to the TYM and probably more $$. My apology if I made this more confusing by mixing them up.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2000 Volvo Semi (A59814)
2000 Volvo Semi...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
Deere 35G (A53317)
Deere 35G (A53317)
Zero Turn Mower (A59231)
Zero Turn Mower...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
