Max 28 100 hour service
/ Max 28 100 hour service #1
mitchash
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
It's time for my Max 28 to get its 100 hour service. I have done everything except the hydro/hydraulic oil. I need to find enough pans to collect the 23 quarts of oil. Is there a screen in the transmission that needs to be cleaned? I know the Kubotas at work have a screen. I also found out the front axle takes the same hydraulic oil. When I first bought it the shop said the front axle took 80/90 gear oil. But since we live in the northeast and it gets so cold here the factory recommends using the hydraulic oil in the front axle. I use all the Mahindra oils and filters since it's still under warranty.
/ Max 28 100 hour service #3
My tractor holds 8 gallons. I have 3 drain plugs, drain each rear axle one at a time. Then I drain the main tranny plug. I know its somewhat messy but I drain so much out then quickly put the plug back in just enough to stop the flow. I don't like trying to maneuver a big container around full of oil, plus its easier to put it in the waste oil container.
I never thought about those cheap totes! Great idea! Thanks!
I didn't notice anything in the manual about cleaning the transmission screen. Anyone clean the screen in there Max 28?
John Deere 2210 Field Cultivator 43' (A63688)
John Deere 2210...
2025 32in. Tilting Bucket Mini Excavator Attachment (A61572)
2025 32in. Tilting...
1079 (A64280)
1079 (A64280)
LP Tank (A64119)
LP Tank (A64119)
GOLF CART (A64280)
GOLF CART (A64280)
2024 Freightliner M2 106 Altec DM47B-TR Insulated Digger Derrick Truck (A61573)
2024 Freightliner...
