MAX 25 BACKHOE DEINSTALL AND INSTALL
/ MAX 25 BACKHOE DEINSTALL AND INSTALL
Thanks when u all see the vid can u leave a comment and over on utube also thanks
/ MAX 25 BACKHOE DEINSTALL AND INSTALL #4
Very good video. I considered buying one of those new when I bought my used Kubota B26. The Mahindra looks to be a bit of an ordeal to get off and on with all those pins to align.
I am glad I got the Kubota which comes off with removal of two top pins and disconnect of 2 hydraulic hoses, one of which is simply plugged back into the tractor making a loop so no valves to set for backhoe vs 3 PH. It takes maybe 2 minutes tops to get it off. You do have to install the 3 PH lift arms though as they cant be on when using the backhoe so another 5 minutes for that.
/ MAX 25 BACKHOE DEINSTALL AND INSTALL #5
That 2nd set of pins, is just to hold up the 3ph arms so you don't have to remove them, they have no structural purpose.
Deere 120 (A64119)
Deere 120 (A64119)
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
Caterpillar 963C/953C Track Loader Service Manuals (A63117)
Caterpillar...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
Bomag Roller (A63689)
2020 CATERPILLAR 262D3 SKID STEER (A64279)
2020 CATERPILLAR...
