Massey Mid-Mount mower
/ Massey Mid-Mount mower #1
Wineguy
Massey Ferguson 1835M Cab
I’m looking at ordering a Massey 72” mid-mount mower (Model 1705) run from a Massey 1835M.
I have about 3 acres of native grasses. Has anyone used this particular mower, and able to comment on its performance? How it performs in taller grass etc…. ?
Thanks,
Wineguy
/ Massey Mid-Mount mower #2
I can't comment on that model, but after owning a mid-mount I recommend thinking about how often you expect to attach/remove the mower deck. Keep in mind that blade maintenance will require removing the deck unless you have a pit. The Kubota I had required a fair amount of time under the tractor to hook up and dismount. A mid-mount is a bit easier to use than a finishing mower especially if there is a lot of stuff to maneuver around. However, for mower maintenance, ease of hookup the finishing mower is the winner. I have a 72" Woods on my MF1840 and am quite happy with its performance.
Thanks for the feedback. I know Massey (Agco) is in bed w/ Woods, so guessing it may be the very same mower you have, just w/ a different name.
I currently have a 60” mid mount on the GC Massey I’m trading in. I ended up buying 2 sets of ramps, and am able to drive up all 4 tires & allow enough clearance to remove/install blades.
/ Massey Mid-Mount mower #4
You never said what the field is used for.
Is it a meadow or is it a part of an extended lawn.
If you plan on maintaining it and want a lawn quality cut I would get the mid-mount.
If this a maintained meadow I would get a 3pth Bushhog.
I mow aboot an acre+ around the house and barn with my GC2300 and it's mid-mount mower.
Good job and all but I don't think that long term I would want to cut the rest of my property with this setup.
The Bushhog is tougher and better able to handle Sh-it that happens like branches, stumps, burrows...
And the advice from CaptPat.
My setup is strictly for cutting lawn as I have other tractors.
If you plan on using yours for other jobs installing and removing the mid-mount can become a pain.
Even greasing the universal joints on the PTO shaft is a taxing procedure.
I also find that cutting taller grasses the clippings pile up on the front of the deck and get into the guards and pulleys.
Especially when it's a bit wet in the morning. Then I have to raise the deck and back up out of the pile.
Doesn't really happen with a 3pth machine.
/ Massey Mid-Mount mower #5
I personally would be spending so much time installing and removing MMM because most of my Tractor work requires agility the MMM would hinder.... Have 2 JB riders for all my mowing and the seem to me a better option from what I mow on my acreage.... You might get a decent rider for less then what a MMM will cost you to add to your tractor....
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
New, Landhonor Skid Steer Pallet Fork  (A62679)
New, Landhonor...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2013 Nissan Pathfinder SUV (A64557)
2013 Nissan...
2022 MAXEY MAXX-D 40’ GOOSENECK EQUIPMENT TRAILER (A59914)
2022 MAXEY MAXX-D...
1985 John Deere 2550 Tractor (A62679)
1985 John Deere...
