Massey Ferguson 1740M Hydro: LOSS OF POWER when hot!
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #51
This may be my final resolution if the Hyd oil change & filters doesn't resolve the issue. My dealer says they want it back, I just don't want another 4 weeks without it, especially in mowing season... hence why I'm tryin everything "I" can do first.
You guys have been great BTW! I want to thank everyone involved in this thread!!!!!
VERY grateful to be here w you all! (or would that be Y'all!) :)
-KJ Miller
Did you ever get this resolved?
No sir, I told my dealer that we should continue this quest maybe in the dead heat of summer, like when my grass isn't growing as fast and needs almost 2 mowings a week!
Still have no hard leads TBH; as to where or what to point the finger at?. We have had a some other 1735M and 1740M owners come forward and say they have the exact same problem. Hopefully maybe we can get a Massey Ferguson / Agco Rep to take notice!?
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #53
Just a random thought, but have you checked to see if the fuel bowl is full at the time you're losing power? Should be full with no vacuum space in there. Just thinking back to a problem I had with my last MF.
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #54
This is turning out to be a real ball-buster... I went back over every post in this thread & it is baffling. I'll toss in a couple more thoughts:
1. Absolutely stick with your dealer and service rep in trying to get to the bottom of it (and of course retain guarantee coverage.)
2. I would suggest picking about 5 or 6 key spots [to take temperature with a hand held infrared thermometer] on your transmission, including an underbelly spot where trans fluid would pool in the sump, the side of the engine head, etc. You seem like a guy who would readily "take data" so do that at say 3 time points into one of your mowing days -- 5 minutes in, 20 minutes in and then at least once in the 50 minute range (after the disease has arrived.) After multiple mowing days worth of data are they all the same pattern of temperature progression? Any clues emerge?
3. I confess some ignorance here (thinking of older tractors) but doesn't this one have a governor? Maybe after your 40 minute disease hits, the governor has ceased to function correctly and no longer brings on the rpm boost it should to keep things going ?? [This thought sort of relates to the "reprogramming" your dealer was trying in that the electronics most likely calls for more rpm on a programmed basis much like what old governors once did.] But that takes me right back to the question: Does this tractor have a governor and might it be malfunctioning? Seems to me it might be the governor itself rather than the controls for the governor.
Please keep us updated and of course good luck to ya.
Fuel Bowl? I know what that is in a gas/carbureted model, but being this is diesel so I am clueless. Can you detail more?
Hi JWR
1. Will do, my dealer has been good to me. And, I have a Youtube channel and have made positive plugs for them previously.
2. I own a laser pointed heat gun, so this would be no problem at all. My concern is that nothing seems like wave like heat coming from anywhere on the engine or tranny. But I can do this.
3. No governor that I'm aware of. Once it goes into this power reduction mode, I think of it more as a "limp mode" kicking in. It's so weird, I need to have a direction to start somewhere, and my dealer should know of any thermo protection thing, right?
Thank you kindly! :)
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #57
Hi JWR
For sure your dealer should know of thermal protection if it is there, AND whether there is a "limp mode" like modern cars/trucks have. Yours does not quite act as extreme as "limp mode" (at least the kind I have had happen on my F-150. It doesn't slow down it goes dead and then can barely be moved after restarting.) I have not heard whether tractors have a 'safe mode' or 'limp mode.'
The data gathering with the laser pointed thermometer that I suggested may very well not show anything remarkable. Just wondering if some pattern might emerge in what has to be a rather wild circumstance.
Have you ever had way to try your machine in real heavy, deep grass or with some other tougher load like a bush hog in heavy brush/deep weeds? I'm wondering if that would bring on the disease quickly OR just confirm the "40 minute rule.?"
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #58
fuel filter bowl may be what other poster meant.
Agree it's not like any Limp Mode I've experienced on other vehicles. So I drought that honestly, and why I never embarked on this in earlier posts.
It will mow through 1 ft tall grass like no other, no slow ups, no RPM drops well until maybe 30 mins or so then. So loading the workload up more will force this power loss to appear sooner yes, and if you look back you will see me telling that putting on the A/C brings up the power loss a bit sooner.
  • Good Post
Reactions: JWR
If that's the case, I did change both fuel filters now twice, thinking originally this was the issue.
Not sure how you could ever tell if there an air pocket in there or not, it's just not a visible aspect I could pursue in any workable to visual inspection.
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2013 John Deere 245G LC (A55272)
2013 John Deere...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
EZ-GO Electric Golf Cart (A57149)
EZ-GO Electric...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
2013 Yamaha YDREX4 Golf Cart (A56859)
2013 Yamaha YDREX4...
