Masonary bits sizing
/ Masonary bits sizing #1
yelbike
Near Winnipeg, Mb, Canada
John Deere 2305, 2320,Z465
Okay so I'm buying a Bosch 1 9/16 rotary hammer 11240.:thumbsup: I need a few bits to go with it but I don't know what size.:confused:I need a bit for 1 1/4" PVC and 2" PVC. Does anyone know what that corrolates to. I don't mind a tight fit. I don't like a slopy hole. No pun intended. :licking:
/ Masonary bits sizing #2
Basically you go a half over so 1 3/4 and 2 1/2.
/ Masonary bits sizing #3
You will need core bits for holes those sizes. Sit down before you ask the price.
The best prices I found were on Amazon. I needed 2 1/4" and pricey doesn't begin to describe these things.
/ Masonary bits sizing #4
If the appearance is not critical, I use a 1/4" hammer drill bit. Draw a circle and then start drill holes around the diameter, with a small gap between them. Now take a hammer and bust the core out.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
(2) FIRESTONE WILDERNESS LE-265/70R16 TIRES (A64280)
(2) FIRESTONE...
2003 Ford F-350 Flatbed Sprayer Truck (A61573)
2003 Ford F-350...
2016 KOMATSU D61PXI-24 CRAWLER DOZER (A64279)
2016 KOMATSU...
4' 3pt Disc Harrow (A64119)
4' 3pt Disc Harrow...
