Masonary bits sizing
/ Masonary bits sizing #1
yelbike
Near Winnipeg, Mb, Canada
John Deere 2305, 2320,Z465
Okay so I'm buying a Bosch 1 9/16 rotary hammer 11240.:thumbsup: I need a few bits to go with it but I don't know what size.:confused:I need a bit for 1 1/4" PVC and 2" PVC. Does anyone know what that corrolates to. I don't mind a tight fit. I don't like a slopy hole. No pun intended. :licking:
/ Masonary bits sizing #2
Basically you go a half over so 1 3/4 and 2 1/2.
/ Masonary bits sizing #3
You will need core bits for holes those sizes. Sit down before you ask the price.
The best prices I found were on Amazon. I needed 2 1/4" and pricey doesn't begin to describe these things.
/ Masonary bits sizing #4
If the appearance is not critical, I use a 1/4" hammer drill bit. Draw a circle and then start drill holes around the diameter, with a small gap between them. Now take a hammer and bust the core out.
Geringhoff Control and Manuals (A63117)
Geringhoff Control...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
RoGator and Terragator Manuals (A63117)
RoGator and...
2016 International Workstar 7500 T/A Dump Truck (A61573)
2016 International...
2009 Stertil Koni ST-1082R 18000lbs 2-Post Auto Lift (A61573)
2009 Stertil Koni...
