Markham Tooth bar Advice
/ Markham Tooth bar Advice #1
Piedmont
NC, USA
JD 2520
The UPS guy just dropped the 53” Makham tooth bar that I plan on installing this weekend. Any advice or is it as straight forward as it seems. Thanks for the great advice here, TBN is a great resource. By the way it weighed in at 65 Lbs.
/ Markham Tooth bar Advice #2
Stright forward. PLace the toothbar on the edge so it fits tightly and evenly along the bucket edge and mark your holes on the sides in the toothbar slots. Drill the holes and you're all set.
/ Markham Tooth bar Advice #3
If necessary, use flat washers between the toothbar and the side wall of the bucket to "take up any slack" to avoid bowing the walls of the bucket...
/ Markham Tooth bar Advice #5
All good pointers, and I used each of these pointers when installing mine.
1. C-clamped the toothbar in place. Tapped teeth with hammer, made sure it was even all the way across, making contact with the buckets cutting edge.
2. scribed the hole's outline on interior of bucket. Removed toothbar and determined dead-center. Centerpunched.
3. Drilled starter hole with approx. a 1/4" bit, to maintain control. After this, you can drill it from the outside of the bucket, a little easier than wrestling with the drill from the interior of the bucket (IMHO).
4. Use washers between toothbar flange and interior of bucket, if there is any appreciable space in there. example: 2 washers on each side, etc.
It should be fairly snug in there, not super-tight, just so you aren't bowing the bucket inward as you tighten the bolts.
4a. Alternate method: weld a a piece of spacer metal on the outside of each toothbar flange if you are looking at a good amount of gap.
In other words, if there is 1/2" of gap either side, you can weld [2] 1/4" peices of flat bar (drilling and matching the hole in the tothbar flange, of course).
It's pretty straight forward, took me 15 or 20 minutes, and most of that was eyeballing the set-up.
Show us pics when it's installed! ;)
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2020 KENWORTH T880 TRI-AXLE HYDROVAC TRK (A67714)
2020 KENWORTH T880...
2015 Ford Taurus AWD Sedan (A66738)
2015 Ford Taurus...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
