Markham bar a little short.
/ Markham bar a little short. #1
MDM
Platinum Member
East Ohio
Kubota L2800HST
I just got my Markham tooth bar. Very nice. The problem is it is 1/4" shorter than it is supposed to be. I realize it is supposed to be 1/4" shorter than the inside dimension, but mine is an additional 1/4" short of that, meaning it is actually 1/2" short. Inside dimension of my bucket is 58 3/8", the bar is 57 7/8". I don't want to bother them for .25".
Would it hurt anything to make up the difference be shimming it out with washers?
/ Markham bar a little short. #2
Not at all...I shim mine all the time. I have about ¼" clearance on both sides.
Just find a couple of nice flat washers about 1/8th to 3/16th's thick. Buy a few spares while you're there.
/ Markham bar a little short. #3
You don't even need to bother with shims. Just tighten the bolt until it draws the attachment tongue to the bucket wall. You can easily bend the thing into submission just with your socket wrench.
/ Markham bar a little short. #4
Very true, and I've done it. It did make mine a bit harder to install, so I hammered the attaching arm straight again. However, that won't necessarily be the case with MDM's tooth bar.
BTW, my tooth bar is on and off frequently. I just want to keep it an easy on-off situation...
/ Markham bar a little short. #5
Mine was a little short also. In this case it is better a little short than long. I welded a couple of 2x2 1/4 inch steel to both sides of the groove. It would be ok without the spacers but I feel better with them.
/ Markham bar a little short. #6
I see from JohnK's photo that Markham has started using a slot rather than a round hole on the attachment tab/tongue. That is nice as it will make measurement for drilling the hole in the side of the bucket less critical.
/ Markham bar a little short. #7
And will allow for pivoting the tooothbar up for back dragging.
/ Markham bar a little short. #8
I never really tried to flip it up while it was on there. I'd say the slots are about2" long so it probably will. When I get to it I'll let yous' know. It is better a little short { At least it will fit} then to long. I ordered one a couple years ago for my other tractor and it was a very snug fit. Almost had to beat it on with a hammer. They probably got complaints and if it was 1/16 too wide it was a lot of trouble to get it to fit. Won't hurt anything being short, I just wanted to fire up the welder and tack the 2 little plates on. Good release when you get home from work...
/ Markham bar a little short. #9
I guess I got kinda lucky, mine just slid right in. I guess there probably are a few millimeters clearance on each side. But, as stated above, much better to have it slightly too short than too long.
There was some discussion a while back on the slotted hole. Someone actually had called Markham and asked about it. The reasoning is that it's for a margin of error. Melissa had told someone here that it's because us guys get so excited when we get our toothbars we are so quick to try to install them that sometimes our drilled hole may be off by a millimeter or so. So the slot allows us guys to be guys. . .like children on Christmas morning with a new toy!!:D
/ Markham bar a little short. #10
I did as johnk did by welding shims to the bar so it would fit better without bending the tabs.
/ Markham bar a little short. #11
When I installed mine I simply slid the tooth bar onto the bucket...took my sledge and tapped the mounting tabs until they were flush (with the sides of the bucket) then drilled and tightly bolted....worked for me. My toothbar stays permanently mounted.
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2026 Electric Tricycle (A64194)
2026 Electric...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
Tennant 5680 (A64127)
2016 Volvo Semi Truck (A66285)
2016 Volvo Semi...
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
