Man Sized Hedge Trimmer
/ Man Sized Hedge Trimmer
That is pretty nifty! Do you need the tire chains for this job, or do you just leave them on all the time?
The link pycoed posted looks like some Mad Max nightmare contraption!
I just leave them on.
/ Man Sized Hedge Trimmer #22
It appears that quite a bit of the dross falls into the bucket!
/ Man Sized Hedge Trimmer #23
What size GPM motor are you using?
/ Man Sized Hedge Trimmer #26
I have a hedge row that is about 250 feet long and it takes me several days every year to trim it with an electric hedge trimmer. I decided to build a man sized hedge trimmer for my Kioti. I went looking for a sickle bar for a Cub and found one. I sand blasted it and painted it then started designing a mount and drive system for it. I bought a hydraulic motor and machined an eccentric flywheel. I took it out for a test drive and it now takes me less than an hour to trim the entire hedge row.View attachment 564482View attachment 564479View attachment 564480View attachment 564481
Man Sized Hedge Trimmer - YouTube
Very nice! Do you happen to know the GPM that your machine is running through that circuit?
/ Man Sized Hedge Trimmer #28
That's Kiwi's for you! -They're all nuts - have you seen them playing rugby?
Bruce
Well according to the spec sheet the pump will do 7.66 gpm. I knew that before I bought the pump. I wanted to run the motor at around 500 to 600 rpm so the one that I bought would be just about right with the lower gpm system.
/ Man Sized Hedge Trimmer #30
Thanks. The reason I ask is I have thought about that very attachment several times. My machine is all hydraulic. I have a hydraulic circuit that I run my brush cutter and mower with that puts out 8GPM@2500psi. Sounds very doable in my situation. Thanks again. :thumbsup:
High Hood All Aluminum Timpte 720 Trailer (A63118)
High Hood All...
2015 Bobcat T770 Compact Track Loader (A64047)
2015 Bobcat T770...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
2012 Kinze 3600 Planter (A63109)
2012 Kinze 3600...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
